Hyundai [0000345] Tài liệu đào đạo Hyundai Step 1 ( 2007) : EPS & MDPS System
Thảo luận trong 'Tài liệu - phần mềm sửa chữa ô tô' bắt đầu bởi khoadongluc, 13/8/12.
  1. khoadongluc
    Nothing Is Impossible
    Thành viên BQT
    17/3/09
    22,752
    7,110
    2,289
    Giới tính:
    Nam
    39,504 lít xăng
    #1 khoadongluc, 13/8/12
    Tài liệu đào tạo Hyundai Step 1 tiếng anh 2007 : EPS & MDPS System
    Định dạng : Ppt , doc
    Dung lượng :16,5 MB
    Trang : 8-102-133
    Năm phát hành : 2007
    HYUNDAI MOTORS
    Chonan Technical Service Training Center
    407-7, Yongdu-Ri, Byungchon-Myun, Chonan-City,
    Chungnam,330-863, Korea
    TEL : 82-41-559-2960 FAX : 82-41-561-0584
    CONTENTS
    1. POWER RACK AND PINION STEERING
    1) SYSTEM CONSTRUCTION ---------------------------------------------------------------------
    2) RACK-AND-PINION STEERING LINKAGE ------------------------------------------------
    3) RACK-AND-PINION STEERING ASSEMBLY ---------------------------------------------
    4) CUTAWAY OF A RACK-AND-PINION STEERING GEAR ------------------------------
    5) OPERATION OF THE PINION AND VALVE ASSEMBLY -------------------------------
    2. POWER STEERING PUMP
    1) OIL PUMP CONSTRUCTION -------------------------------------------------------------------
    2) OPERATION OF THE OIL PUMP -------------------------------------------------------------
    3) RELIEF VALVE -------------------------------------------------------------------------------------
    4) FLOW CONTROL VALVE -----------------------------------------------------------------------
    3. OIL REPLACEMENT ---------------------------------------------------------
    4. AIR BLEEDING ----------------------------------------------------------------
    5. OIL PUMP PULLEY AND BELT REPLACEMENT -------------------
    EPS(Electronic Power Steering)
    6. EPS GENERAL
    1) SYSTEM LAYOUT ---------------------------------------------------------------------------------
    2) EPS FEATURES -----------------------------------------------------------------------------------
    3) TYPES OF EPS SYSTEM -----------------------------------------------------------------------
    7. FLOW CONTROL TYPE EPS SYSTEM
    1) EPS SOLENOID ------------------------------------------------------------------------------------
    2) OPERATION -----------------------------------------------------------------------------------------
    8. REACTION TYPE EPS SYSTEM
    1) CONSTRUCTION ----------------------------------------------------------------------------------
    2) ROTARY VALVE -----------------------------------------------------------------------------------
    3) COUNTER-FORCE PLUNGER ----------------------------------------------------------------
    4) PCV OPERATING PRINCIPLE -----------------------------------------------------------------
    9. DIAGNOSIS AND TROUBLESHOOTING
    1) EPS OPERATING PRINCIPLE -----------------------------------------------------------------
    2) EPSCM INPUT & OUTPUT ---------------------------------------------------------------------
    3) EPSCM LOCATION & PIN LAYOUT ---------------------------------------------------------
    4) EPS SOLENOID VALVE -------------------------------------------------------------------------
    5) CURRENT CONTROL OF THE SOLENOID VALVE -------------------------------------
    6) TROUBLESHOOTING ----------------------------------------------------------------------------
    10. EPSCM HI-SCAN PRO DATA --------------------------------------------
    MDPS(Motor Driven Power Steering)
    11. GENERAL
    1) Advantages -----------------------------------------------------------------------------------------
    2) The merits of MDPS ------------------------------------------------------------------------------
    3) Comparison of the construction -------------------------------------------------------------
    4) Types of the EPS ----------------------------------------------------------------------------------
    12. CONSTRUCTION OF COLUMN TYPE EPS
    1) General specification for Unit ----------------------------------------------------------------
    2) ECU block diagram -------------------------------------------------------------------------------
    13. INPUT SIGNALS
    1) Torque sensor (Main, Sub) ---------------------------------------------------------------------
    2) Vehicle speed signal -----------------------------------------------------------------------------
    3) Ignition (Engine speed) -------------------------------------------------------------------------
    4) Warning lamp control ---------------------------------------------------------------------------
    5) Idle up control -------------------------------------------------------------------------------------
    6) Motor control ---------------------------------------------------------------------------------------
    14. TIMING CHART --------------------------------------------------------------
    15. DIAGNOSIS AND TROUBLESHOOTING
    1) ECU Pin terminal diagram ---------------------------------------------------------------------
    2) Terminal Assignment of Connector --------------------------------------------------------
    3) Input / Output terminal voltage (Reference) ---------------------------------------------
    4) Failsafe -----------------------------------------------------------------------------------------------
    5) Basic Inspection ----------------------------------------------------------------------------------
    6) Parts replacement and failure diagnostic operations --------------------------------
    7) Inspection to be performed when the Warning lamp does not turn on ---------
    8) Defect of the power supply system ---------------------------------------------------------
    9) Sensor malfunction difficult to be detected by self-diagnosis --------------------
    10) Code specific fault diagnosis ---------------------------------------------------------------
    11) Inspection according to the Diagnosis trouble code -------------------------------
    12) Inspection According To the Defective Phenomena --------------------------------
    13) Diagnostic Trouble Code & Causes -------------------------------------------------------
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Các file đính kèm:
