javaro_2405
The 1997 Honda Civic is driven by a 1,590 cc 1.6 liters 4 in-line front transverse engine with 75 mm bore, 90 mm stroke, 9.4 compression ratio, light alloy block, light alloy head, overhead cam and four valves per cylinder.
The following schematic shows the 1997 Honda Civic Cooling Fan Wiring Circuit Diagram. This system consists of: powertrain or engine control module, under-dash fuse/relay box, radiator fan relay, condenser fan relay, A/C pressure switch, A/C thermostat, radiator fan motor, condenser fan motor, and engine coolant temperature switch.
