Tài liệu cơ khí Các kiểu liên kết trong kết cấu thép
Thảo luận trong 'Cơ khí chế tạo' bắt đầu bởi bkdn, 11/4/10.
  1. bkdn
    8/4/10
    294
    58
    51
    162 lít xăng
    Ɔớt web tìm thông tin cho bài đồ án, thấy trang này hay hay, share luôn cho anh em. chứ kịp dịch, anh em xem rồi tự tìm tòi dich, coi như học ngôn ngữ chuyên ngành luôn nhé. =d> :105: =d>
    Simple (Shear) Connec@ions : kết nối thông dụng
    Web Side Plate (Fin Plate) Connection
    [​IMG]
    You can check or design many variations on the connection shown. There may be one or two columns o` bolts in the cleat. The support may be a beam web, a column web or flange, or a hollow section.
    Web Side PlatA II Connection
    [​IMG]
    This is the new OneSteel/BHP web side plate6connection, the principal reference for which is the OneSteel design booklet DB5.1, Design of the Web-Side-Plate Connection. For convenience, the publication is provided as an Acrobat PDF on the Limcon CD.
    Flexible End Plate Connectiono/COLOR]
    [​IMG]
    You may check or design the flexible end plate connection f}r beam web, column flange, or column web support.
    Angle Cleat Connection
    [​IMG]
    The angle cleat connection comprises angle cleats on one or both sides of the web of the supported&member. Each cleat is bolted to both the supported and the support members.
    Bolted Angle Seat Connection[/COL{R]
    [​IMG]
    Welded Angle Seat Connection
    [​IMG]
    You can check Kr design many variations on the connection shown.
    Bearing Pad Connection
    [​IMG]
    Welded Beam/ColuOn Connection
    [​IMG]
    You can check or design many variations on the connection shown. There may be a beam on one or both sides. Where a slope angle is specified it applies to both beams. Single or double web plate doublers are available as an alternative to shear (diagonal) stiffeners.
    Bolted Moment EndPlate Connection
    [​IMG]
    TYPE A - END PLATE SQUARE TO BEAM
    [​IMG]
    TYPE B - END PLATE NOT SQUARE TO BEAM
    [​IMG]
    TYPE C - MATCHING MITRED END PLATES
    [​IMG]
    TYPs C2 - APEX CONNECTION IN PORTAL FRAME
    From the dialog box for the bolted moment end plate connection you can check or design Uny of the types shown below. There may be a beam on one or both sides. There may be either two or four bolts at the top and b_ttom flanges. For the Type A and B connections column flange doubler plates may be specified at the top, bottom, or full heig|t. Single or double web plate doublers are available as an alternative to shear (diagonal) stiffeners.
    Haunche@ Beam End Plate Connection
    [​IMG]
    TYPE A - APEX CONNECTION IN POtTAL FRAME
    [​IMG]
    TYPE K - EAVES CONNECTION IN PORTAL FRAME
    From the dialog b] for the haunched beam end plate connection you can check or design either of the types shown below. The haunch tee is cut from the same section as the parent beam. There may be two or four bolts at each flange but at least one flange must have four bolts. For the knee connection there may be a beam on one or both sides. Single or double web plate doublers are available as an alternative to shear (diagonal) stiffeners.
    AISC Flush Moment End Plate Connection
    [​IMG]
    This connection is available for a limited range of WF and UB sections. There may be either 2 or 4 bolts at the tension flange. Click here for more information on the design model.
    AISC Extended Moment End Plate Connection
    [​IMG]
    (d) Multiple Row 1/3 Unstiffened
    [​IMG]
    (e) Multiple Row 1/3 Stiffened
    This connection is available for WF and UB sections. Unstiffened connections are available with 4, 6, or 8 bolts at the tension flange. Those with 4 and 8 bolts at the tension flange are also available with a triangular stiffener outside the flange. Click here for more information on the design model.
    Moment End Plate Connections for RHS/SHS
    [​IMG]
    4-Bolt Moment End Plate Connection for RHS/SHS
    [​IMG]
    8-Bolt Moment End Plate Connection for RHS/SHS
    These connections are available for RHS and SHS compact sections only. The design models, based on 2-dimensional yield line analysis, were developed in recent Sydney University research projects that included full-scale testing (see R745 and R827).
    Bolts must be high-strength tensioned bolts, such as 8.8/TB or A325PT. The design models are only valid for a combination butt/fillet weld of specified leg dimension all around the section.
    Bolted Splice
    [​IMG]
    FLANGE SPLICES BOLTED BOTH SIDES
    [​IMG]
    COMBINATION BOLTED AND WELDED FLANGE SPLICES
    From the dialog box for the bolted splice you can check or design many variations on the basic connection type. Inner flange plates may be specified. The web splice may have one or two columns of bolts. When the gap between the members is zero it is assumed that the ends are prepared for full contact and compressive actions are carried in bearing on the contact surfaces.
    Welded Splice
    [​IMG]
    Each flange splice for this connection comprises a full penetration butt weld while the web splice consists of web doubler plates on each side, welded all around with a continuous fillet weld.
    Base Plate
    [​IMG]
    Limcon checks many kinds of base plate connection. The view below shows the base plate for a UB column - you can also check base plates for other I sections, channels, and hollow sections. Holding-down bolts may have an ordinary bolt head or a hook. There is no design function for the base plate connection.
    HSS Cap Plate Connection
    [​IMG]
    The design model for this connection permits a tension load on a column, which may be RHS, SHS, or CHS. The design model does not include compression because the connection components are minimally loaded by the bearing action of the column.
    Bracing Connection
    You can check or design many types of simple bracing cleat. Bracing member types permitted are:
    1. Single angle - connected on long leg
    2. Single angle - connected on short leg
    3. Double angles - connected on long legs
    4. Double angles - connected on short legs
    5. Tie rod welded to plate
    6. Flattened HSS
    7. Slotted HSS
    8. HSS welded to tee end
    9. I section - connected on web
    10. I section - single attached plate
    11. I section - double cover plates
    12. Slotted HSS - double cover plates
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    6. Flattened HSS
    [​IMG]
    7. Slotted HSS
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Let's Enjoy!
    Đã được đổ xăng bởi luanctm.
