Toyota / Lexus cách cài remote yaris 2008,rav4 2006 e sưu tầm được
Thảo luận trong 'Thảo luận kỹ thuật sửa chữa' bắt đầu bởi bathinh, 24/2/15.
  1. bathinh
    28/9/14
    247
    181
    76
    Giới tính:
    Nam
    2,954 lít xăng
    2008 Yaris
    1- Driveres door open & unlocked. Key out of ignition
    2- Insert & remove key 2 times within 5 seconds
    3- Close & open drivers door twice within 40 seconds
    4- Insert key into ignition & remove
    5- Close & open drivers door twice within 40 seconds
    6- Insert key into ignition
    7- Close the door
    8- Turn ignition switch from "LOCK" to "ON" & back to "LOCK"
    - ONCE for ADD mode
    - TWICE for REWRITE mode
    9- Remove the key from ignition
    10- To confirm your mode selection, the power locks will now cycle "lock" to
    "unlock" a number of times corresponding to your key cycles in step 8
    11- Within 40 seconds of confirmation
    - Press both transmitter Lock & Ulock buttons simultaneously
    - Within 3 seconds press transmitter Lock button for more than 1 second
    - If successful, the power locks will cycle once (twice indicates
    transmitter problems)
    - Repeat step 11 for additional remotes
    12- Open door to exit programing
    .the end.
    rav4:
    1. Start w ith the key out of the ignition, driv ers door is open all others closed and
    driv ers door is unlocked.
    2. Perform these steps w ithin 5 seconds.
    A. Insert the key into the ignition(Do NOT Turn) Pull key out.
    B. Insert the key into the ignition(Do NOT Turn) Pull key out.
    3. Perform these steps w ithin 40 seconds.
    A. Close then open the driv ers door.
    B. Close then open the driv ers door.
    C. Insert the key into the ignition(Do NOT Turn) Pull key out.
    4. Perform these steps w ithin 40 seconds.
    C. Insert the key into ignition and leav e it in ignition.
    D. Close the driv ers door.
    E. Turn the ignition to ON (Do NOT Start) then back to OFF.
    F. Remov e the key from the ignition.
    5. Within 3 seconds, the pow er door locks should lock then unlock automatically
    indicating successful entry into programming mode.
    Return to step 1 if the locks do not cycle at this point.
    6. Perform these steps w ithin 40 seconds.
    A. Press the lock and unlock buttons on the remtoe simutaneously for 1.5 seconds.
    B. Immediately after letting go of the lock and unlock buttons,
    Press the lock button by itself and hold for 2 seconds. Within 3 seconds, the door
    locks should lock and then unlock once indicating successful programming. If
    the door locks cycle tw ice, repeat steps A and B in step 6 as the remote w as
    not accepted.
    C. Repeat steps A and B in step 6 for each new remote.
    7. Open driv ers door.
    .the end.
    Đã được đổ xăng bởi namphuong007, vuquocdat, anhchangbibibi5 tài xế khác.
