Tài liệu đào tạo Difference between MUI and EUI in cylinder head
Thảo luận trong 'Các vấn đề về thủy lực & ứng dụng' bắt đầu bởi khoadongluc, 25/1/10.
  1. khoadongluc
    Nothing Is Impossible
    Thành viên BQT
    17/3/09
    22,752
    7,108
    2,289
    Giới tính:
    Nam
    39,371 lít xăng
    This picture shows the difference between the Mechanical Unit Injection (MUI)
    and current Electronic Unit Injection (EUI) installation in the cylinder head.
    Notice the Helper Spring on the injector pushrod. This arrangement is designed
    to keep the follower in constant contact with the camshaft. The helper spring is
    required due to the increased injection pressures of 151 MPa (22000 psi) and the
    steeper, high lift camshaft lobe profile.
    The 3500B has a larger diameter camshaft to accommodate the higher injection
    pressures generated in the unit injector pumps.
