Tài liệu đào tạo Động cơ diesel 4 thì
Thảo luận trong 'Máy nông nghiệp - Máy khác' bắt đầu bởi hyundai, 27/7/11.
  1. hyundai
    Bằng lái Hạng F
    7/10/09
    5,181
    2,454
    2,130
    12,744 lít xăng
    Heat engines are sometimes referred to as being motors. Actually, a motor converts one form of energy into useful work without the intentional production of heat, such as an electric motor. A device which burns fuel creating heat to perform work is a heat engine. Heat engines can be classified as external combustion, such as steam boiler, or internal combustion (IC). They can further be divided into the spark ignited (SI) engine or the compression ignited engine (CI). The particular heat engine we are interested about with this webpage, is the Compression Ignited heat engine. This style of engine has been most famously referred to as the Diesel engine, named after it’s inventor, .
    The compression ignited internal combustion engine has two main designs: the four strok cycle, and the two stroke cycle engine. They are both very common throughout the world because of their high efficiency - compare with other types of heat engines. They burn a wide variety of hydrocarbon fuel, which is still common. Heavy fuel oil, intermediate fuel oil and marine diesel oil are the most common hydrocarbon fuel. The two stroke and four stroke titles refers to the mechanical action of the machinery, in particular the piston within the cylinder, to achieve the theoretical Carnot heat cycle, as define by the laws of thermodynamics.
    Diesel engines are furthermore sub-divided into three categories: slow, medium and high speed. Slow speed are considered to be up to 300 rpm such as most big two stroke engines commonly found on ships. Medium speed engines dwell in the 300 - 900 rpm range. They are most common on smaller ships and power plants driving electrical generators and / or the propeller. High speed engines are the most common. Their high revolutions are ideal for driving vehicles such as busses and yachts. All Diesel trucks and vehicles on our roads use this class of Diesels, having an rpm over 900.
    [​IMG]
    [FONT=Trebuchet MS, Arial, Helvetica]The four stroke ...[/FONT]
    [​IMG]
    The four stroke is most commonly seen in application demanding a compact power plant. Ships need a large amount of power to propel it through the water, this is why the bigger ship, as previously mentioned, generally have a two stroke power plant. As illustrated by the pictures on this website, a person can begin to appreciate the physical size of these plants, especially the engine’s height. This height becomes a problem on many coastal ships, such ferries.
    [​IMG]
    Take the British Columbia Ferry Corporation (BC Ferries) MV , a double ender with a GT of 6,551 tons. This ferry, as do most ferry rely, on their ability to load and discharge a large amount of cars, transported on continuous
    [​IMG]
    decks. That creates a problem for the size engine the ferry needs. The power plant needs to fit below the main deck and still be able to go in shallow waters. The engines installed in the Queen of Cowichan are 551 V12. They are a four stroke, turbo charged engine producing around 4,500 kW each. These engine stand less than twenty feet high and serve to illustrate the ideal application of a four stroke engine. A similar engine is pictured to the right.
    Four stroke engines are more complicated than the two stroke and "pack" less horsepower per pound. The two stroke actually produces more power, around 1.8:1. But the four stroke consumes less oil and can operate safely at high speeds. The four stroke Diesel engine is probably the most prevalent engine in all the world. They can be found producing power for [​IMG] oil rigs in the North Atlantic or driving Volkswagen's .
    The Diesel engine uses a light distillate fuel oil, commonly known as Diesel. This of course, is more expensive than the Heavy Fuel Oil (HFO) which is burned more efficiently by the two stroke engines. Recent engine design development has provided bigger four stroke power plants with the ability to burn HFO. This development now makes the four stroke engine an attractive option to ship owners. The newest shipping market to employ four stroke engines are the cruise ships. They use four or five engines driving generators to produce electricity which is used to power the main driving (electric) motors and the "hotel load" (lights, heat etc.). With the cruise ship, we can observe the point made earlier, the need to keep the power plant "small", this is to make room for paying passengers.
    [​IMG]
    Many companies build four stroke Diesel engines. Caterpillar, Cummins, Detroit Diesel engines are the most popular engine manufacturer for highway trucks and smaller applications. Others like MAN (the company that FIRST developed’s engine), MAK, MTU, Wartsila, Deutz - just to name a few, offer a wide range of power plants often found in marine application. Four stroke engines have a power range of 2kW to 25,000kW. These can be found in many V style and inline configurations: V8, V12, V16, V20; the inline 6 being the more popular one.
    [​IMG]
    [FONT=Trebuchet MS, Arial, Helvetica]The mechanics of it...[/FONT]
    The four stroke is outwardly similar to it’s brother, the two stroke. But it’s inner working are quite different. One primary difference is the cylinder liner does not have the inlet ports machined into it. Another is the combustion air being drawn into the cylinder by[​IMG] the piston. This action is controlled by an inlet valve in the cylinder head, like the one to the right. With no need for a blower, this becomes the most radical difference between the four and two strokes engines and as such, the four strokes are called naturally aspirated engines.
    The cycle comprises of: two crankshaft rotation and four change of direction by the piston. We will start with the inlet stroke at top dead center (TDC). See the diagram below for a visual representation.
    At TDC the inlet valve is open allowing air to flow inside the cylinder. The downward action of the piston creates a vacuum which draws air into the cylinder. Shortly before the piston reaches bottom dead center (BDC), the inlet valve is closed. The piston at BDC begins it’s upward travel, beginning the compression stroke. The piston compresses the original air volume by about 17:1 to 23:1, to about 42 bars (~600 psi). The air’s volume reduction crushes the air molecule together and as result they build up heat.
    [​IMG]
    1-2 suction, 2-3 compression, 3-4 injection (fuel)
    4-5 expansion (power), 5-6 exhaust
    [​IMG]At 10 degrees before TDC injection of atomized fuel begins, it burns, ignited by the high temperature from to the air being compressed. Injection stops around about 35 degrees after TDC, depending on the engine’s load. The fuel continues to burn and expands which increase the cylinder temperature and pressure. Around 35 degrees after TDC injection stops, and shortly after maximum pressure is reached within the cylinder, this stage is commonly called Pmax. Pmax is anywhere between 180 bars to 195 bars (~2500 - 2800 psi); this is why Diesel engine construction is so robust, it is to withstand this pressure.
    [​IMG]
    The pressure force acts upon the area of the piston crown, pushing it down. This downward force is transmitted to the crankshaft by the connecting rod, transforming it into a rotational force. At 35 degrees before BDC, the exhaust valve opens allowing the hot exhaust to escape, it's temperature is about 600 degrees Celsius. After BDC, the upward motion of the piston pushes the exhaust out of the cylinder through the exhaust valve. The air intake valve, 15 degrees before TDC, opens and overlaps the exhaust valve, this is to scavenge the cylinder of combustion products. Slightly after TDC, 10 degrees, the exhaust valve closes while the intake valve remains open to admit a fresh charge of air for compression. This completes one cycle of a four stroke engine.
    [​IMG]
