Cơ bản hệ thống phanh trên xe camry
Thảo luận trong 'Khung gầm' bắt đầu bởi dotrungtruc, 10/8/14.
  1. dotrungtruc
    17/10/09
    14
    23
    6
    123 lít xăng
    BRAKESYSTEM
    BR–1
    [​IMG]
    BRAKESYSTEM
    BR–2
    BRAKESYSTEM
    – Precautions
    PRECAUTIONS
    1. Caremustbetakentoreplaceeachpartproperlyasit couldaffect the performance of the brake system and re- sult inadrivinghazard.Replacethepartswithpartsofthe samepartnumberorequivalent.
    2. It isveryimportanttokeeppartsandtheareacleanwhen repairingthebrakesystem.
    TROUBLESHOOTING
    Problem
    Loworspongy
    Linings worn
    Possible cause
    Remedy
    Replacebrakeshoes
    Page
    BR–26
    [​IMG]pedal
    Brake pads worn Leak in brake system Mastercylinderfaulty
    Airinbrakesystem
    Wheelcylinderfaulty
    Replacepads
    Repair leak
    Repairorreplacemastercylinder
    Bleed brake system Repair wheel cylinder Repaircylinder
    Brakecylinderfaulty
    Piston seals worn or damaged
    Repairorreplaceadjuster
    BR–18, 34
    BR–18, 34
    Rearbrakeautomaticadjusterfaulty
    Brakesdrag
    Parkingbrakeoutofadjustment
    Bindingparkingbrakewire
    Adjust parking brake
    Repairasnecessary
    BR–8
    Boosterpushrodoutofadjustment
    Adjust push rod
    BR–16
    Tension or return spring faulty
    Replace spring
    BR–26, 42
    Brake line restricted
    Repairasnecessary
    Lining cracked or distorted
    Replaceshoe
    Pad cracked or distorted
    Replacepad
    BR–26, 42
    Wheelcylinderorcaliperpistonsticking
    Repairasnecessary
    BR–18,34
    Adjuster broken
    BR–18, 26
    34
    Replace adjuster
    Repair or replace master
    BR–9
    cylinder
    Brakespull
    Tires improperly inflated
    Inflate tires to proper pressure
    Check for cause. Replace shoes
    Oil or grease on shoes or pads
    or pads
    BR–18, 26
    Replacebrakeshoes
    34
    Brakeshoesdistorted,liningswornorglazed
    BR–26, 42
    Brakepadsdistorted,wornorglazed
    Drum or disc out of round
    Replacepads
    BR–18, 34
    Replace drum or disc
    BR–18, 26
    Wheelcylinderfaulty
    Replace spring
    34
    Brakecylinderfaulty
    BR–26, 42
    Pistonfrozeninbrakecylinder
    Repaircylinder
    BR–26
    Brake pad sticking
    Repaircylinder
    BR–18, 34
    Replacepads
    BR–18, 34
    BR–18, 34
    Repair brake cylinder
    BR–18,34
    BR–9
    BR–7
    BR–26
    BR–2
    BRAKESYSTEM
    – Troubleshooting
    PRECAUTIONS
    TROUBLESHOOTING
    Problem
    Loworspongy
    Linings worn
    Possible cause
    Remedy
    Replacebrakeshoes
    Page
    BR–26
    [​IMG]pedal
    Airinbrakesystem
    Wheelcylinderfaulty
    Replacepads
    Repair leak
    Brakecylinderfaulty
    BR–18, 34
    BR–18, 34
    Brakesdrag
    Repairasnecessary
    BR–8
    Adjust push rod
    BR–16
    Replace spring
    BR–26, 42
    Repairasnecessary
    Replaceshoe
    Replacepad
    BR–26, 42
    Repairasnecessary
    BR–18,34
    Adjuster broken
    BR–18, 26
    34
    Replace adjuster
    BR–9
    cylinder
    Brakespull
    or pads
    BR–18, 26
    Replacebrakeshoes
    34
    BR–26, 42
    Replacepads
    BR–18, 34
    BR–18, 26
    Wheelcylinderfaulty
    Replace spring
    34
    Brakecylinderfaulty
    BR–26, 42
    Repaircylinder
    BR–26
    Brake pad sticking
    Repaircylinder
    BR–18, 34
    Replacepads
    BR–18, 34
    BR–18, 34
    BR–18,34
    BR–9
    BR–7
    BR–26
    BRAKESYSTEM
    – Troubleshooting
    BR–3
    TROUBLESHOOTING(Cont’d)
    Problem
    Hard pedal but brakes
    Possiblecause
    Remedy
    Checkfor cause. Replace shoes
    Page
    BR–18,26
    inefficient
    or pads
    34
    Brakeshoesdistorted,liningswornorglazed,
    Replacebrakeshoes
    BR–26,
    drumsworn
    Brakeboosterfaulty
    Vacuumleaks
    Replacepads Repaircylinder Repair booster
    Repairasnecessary
    BR–18,34
    BR–18,34
    BR–15
    Repairasnecessary
    Snapping or clicking noise(Drumbrake)
    [​IMG]when brakes are applied
    Brake shoes binding at backing plate ledges
    Backing plate ledges worn
    Loose or missing shoe hold–down spring
    Loose set bolt at backing plate
    (Discbrake)
    Loose or missing pad support plate
    Loose installation bolt
    Replace pad support plate
    Tighten
    Replaceslidebushing
    BR–18,34
    BR–18, 34
    BR–18, 34
    Scraping or grinding noiseWorn brake linings or pads
    Replace or refinish drums or rotors if
    BR–18, 26
    heavilyscored
    34
    Caliper to wheel or rotor interference
    Replace as required
    BR–18, 34
    Dust cover to rotor or backing plate to drum
    interference
    Other brake system components faulty
    Correctorreplace
    BR–18,26
    34
    Repairorreplaceas
    necessary
    Tires rubbing against chassis and/or
    Repairasnecessary
    body
    Wear on slide bushing
    Lubricate
    Replace and lubricate ledges Replaceshoehold–downspring Tighten
    BR–26
    BR–26
    BR–26
    BR–26
    Problem
    Possible cause
    I Remedy
    .Page
    Squeaking,squealing groaningorchattering noise when brakes are applied
    Note: Brake friction
    materials inherently
    Brake drums and linings, rotors and pads
    wornorscored
    Dirty, greased, contaminated or glazed linings or pads
    Improperliningsorpadsusing
    Maladjustmentofbrakepedalorbooster
    Inspect, repair or replace
    Clean or replace
    Inspectforcorrectusageor replace
    Inspect and adjust
    BR–18,26,
    34
    BR–18, 26
    34
    generate noise and heat inpushrod ordertodissipateeniergy.(Discbrake)
    BR–6,16
    As a result, occasional squeal is normal and is aggravatedbysevere environmental conditions such as cold,’ heat, wetness, snow,salt,mud,
    Missing or damaged brake pad
    anti–squeal shim
    Pad wear and pad wear indicator making contact with the rotor
    Burredorrustedcalipers
    (Drum brake)
    Replace
    Replace
    Cleanordeburr
    BR–18, 34
    BR–18, 34
    BR–18, 34
    etc. This occasional squealWeak damaged or incorrect shoe
    isnotafunctionalproblemhold–down springs, loose or damaged
    and does not indicate anyshoe hold–down spring pins and springs
    loss of brake effectivenessandgroovedbackingplateledges
    –Inspect,repairorreplace
    BR–26
    Squealingand squeakingnoisewhen
    Maladjustmentof brake pedal or booster push rod
    Inspect and adjust
    BR–6, 16
    brakes are not applied
    Poor return of brake booster or master cylinder or
    BR–9,15
    wheel cylinder
    (Discbrake)
    26
    Rusted or stuck piston
    Inspect and lubricate as
    BR– 18, 34
    Improperpositioningofpadincaliper
    necessary
    Rotor rubbing against caliper housing
    Repairorreplace
    BR–18,34
    Improperinstallationofdiscbrakepadsupport
    Repairorreplace
    BR–18, 34
    plate
    Repairorreplace
    BR–18, 34
    Replace
    BR–18, 34
    withtherotor
    (Drum brake)
    Weak, damaged or incorrect shoe hold–down
    springs
    Replace
    BR–26, 42
    Grooved backing plate ledges
    Repairorreplace
    BR–26, 42
    Bent or warped backing plate causing
    Repairorreplace
    BR–26, 42
    [​IMG]interference with drum
    Impropermachiningofdrumcausinginterference with backing plate or shoe
    Other brake system components: Loose or extra parts in brakes
    Rear drum adjustment too tight causing lining to glaze
    Worn,damagedorinsufficientlylubricatedwheel bearings
    Replace drum
    Inspect,repairorreplaceas necessary
    BR–26, 42
    BRAKESYSTEM
    – Troubleshooting
    BR–5
    Problem Groaning,clickingor rattlingnoisewhen brakes are not applied
    Possiblecause Stones or foreign material trapped inside wheelcovers
    Loosewheelnuts
    Remedy Page
    Remove foreign material
    Tighten to correct torque Replace if stud holes are elongated
    worn, damaged or dry wheel bearings
    (Discbrake)
    Looseormissinganti–rattlespringorpad support plate or rimping on outer pad Failure of shim
    Loose installation bolt Poor return of piston (Drum brake)
    Looseorextraparts
    Inspect and adjust
    Inspectandlubricateor replace
    Inspect , replace if necessary Inspect , replace if necessary Inspect,tightenifnecessary Inspect, repair or replace
    BR–6,16
    BR–21,37
    BR–21, 37
    BR–21, 37
    BR–21, 37
    BR–21, 37
    [​IMG]Inspect and repair
    BR–26, 42
    StOPlight SwitCh
    PushRod
    CHECKS AND ADJUSTMENTS CHECKANDADJUSTMENTOFBRAKE PEDAL
    1. CHECKTHATPEDALHEIGHTISCORRECT
    Pedalheightfromasphaltsheet:
    177.5–187.5mm(6.988–7.382in.)
    Ifincorrect,adjustthepedalheight.
    2. IFNECESSARY,ADJUSTPEDALHEIGHT
    (a) Ifnecessary,removetheinstrumentlowerfinishpan- elandairduct.
    (b) Loosenthestoplightswitchlocknut. (e) Sufficientlyloosenthestoplightswitch. (d) Loosenthepushrodlocknut.
    (e) Adjustthepedalheightbyturningthepedalpush rod.
    (f) Returnthestoplightswitchuntilitlightlycontactsthe
    pedalstopper.
    (g) Tightenthetwolocknuts.
    (h) Checkthatthestoplightslightwhenthebrakepedal depressed.
    (i) Afteradjustingthepedalheight,checkandadjust
    thepedalfreeplay.
    [​IMG]
    PushRod
    3. CHECKTHATPEDALFREEPLAYISCORRECT
    (a) Stoptheengineanddepressthebrakepedalsever- altimesuntilthere is no more vacuum left in the booster.
    (b) Pushinthepedaluntilthebeginningofresistance isfelt.Measurethedistance,asshown.
    Pedalfreeplay:3–6mm(0.12–0.24in.)
    HINT:Thefreeplaytothefirstresistanceisduetotheplay betweentheclevisandpin.Anditis13mm(0.04–
    0.12in.)onthepedal.
    4. IFNECESSARY,ADJUSTPEDALFREEPLAY
    (a) Ifincorrect,adjustthepedalfreeplaybyturningthe pedalpushrod.
    (b) Starttheengineandconfirmthatpedalfreepiayex- ists.
    (e) Afteradjustingthepedalfreeplay,checkthepedal
    height.
    (d) Installtheairductandinstrumentlowerfinishpanel.
    BRAKESYSTEM
    – ChecksandAdjustments
    PtdtlR.,erve Oistanot
    _.'
    ._
    5. CHECKTHATPEDALRESERVEDISTANCEIS CORRECT
    Releasethe parking brake. With engine running, depress
    thepedalandmeasurethepedalreservedistance,as shown.
    Pedalreservedistancefromasphaltsheetat50kg
    (110.21b):Morethan85mm,(3.35in.)
    Ifincorrect,troubleshootthebrakesystem.
    GOOD
    1St2nd
    NO~OOD
    OPERATIONALTESTOFBRAKE BOOSTER
    HINT:If there is leakage or lack of vacuum, repair before testing.Ifavailable,useabrakeboostertestertocheckthe boosteroperatingcondition.
    1. OPERATINGCHECK
    (a) Depressthebrakepedalseveraltimeswiththeen- ginestopped,andcheckthatisnochangeintheped- alreservedistance.
    (b) Depressthebrakepedalandstarttheengine.Ifthe pedalgoesdownslightly,operationisnormal.
    2. AIRTIGHTNESSCHECK
    (a) Starttheengineandstopitafterone or two minutes.
    Depressthebrakepedal several times slowly.Ifthe pedalgoesdownfurtherestthefirsttime,butgradual- lyrisesafterthesecondorthirdtime,theboosterisair tight.
    (b) Depressthe brake pedal while the engine is running, andstopitwiththepedaldepressed.Ifthereisno
    [​IMG]
    changeinpedalreservetravelafterholdingthepedal
    forthirtyseconds,theboosterisairtight.
    BLEEDINGOFBRAKESYSTEM
    HINT:Ifanyworkisdoneonthebrakesystemorifairissus- pectedinthebrakelines,bleedthesystemofair. NOTICE:Do not let brake fluid remain ona painted surface. Washitoffimmediately.
    1. FILLBRAKERESERVOIRWITHBRAKEFLUID
    Checkthefluidlevelinthereservoir.Ifnecessary,add brakefluid.
    2. BLEEDMASTERCYLINDER
    HINT:Ifthemastercylinderwasdisassembledoriftheres- ervoirbecomes empty, bleed the air from the master cylin- der.
    (a) Disconnectthebrake tubes from the master cylinder. (b) Depressthebrakepedalandholdit.
    [​IMG](c) Blockofftheouterholeswithyourfingers,andre- leasethebrakepedal.
    (d) Repeat(b)and(c)threeorfourtimes.
    3. BEGINBLEEDINGAIRFROMBRAKEORWHEEL CYLINDERWITHLONGESTHYDRAULICLINE
    (a) Connectthevinyltubetothebrakeorwheelcylinder
    bleederplug,andinserttheotherendoftubeina halffullcontainerofbrakefluid.
    (b) Slowlypumpthebrakepedalseveraltimes.
    (c) Whilehavinganassistantpressonthepedal,loosen thebleederpluguntilfluidstartstorunout.Thenclose thebleederplug.
    (d) Repeat(b)and(c)untiltherearenomoreairbubbles inthefluid.
    (e) Tightenthebleederplug.
    Bleederplugtighteningtorque:
    85kg–cm(74in.–!b,8.3N–m)
    4. REPEATPROCEDUREFOREACHWHEEL
    CHECKANDADJUSTMENTOFPARKING BRAKE
    1. CHECKTHATPARKINGBRAKELEVERTRAVELIS CORRECT
    Pull theparkingbrakeleverallthewayup,andcountthenum- berofclicks.
    Parkingbrakelevertravelat20kg(44.1Ib,196N):
    5–8clicks
    Ifincorrect,adjusttheparkingbrake.
    2. IFNECESSARY,ADJUSTPARKINGBRAKELEVER TRAVEL
    HINT:Before adjusting the parking brake, make sure that the rearbrakeshoeclearancehasbeenadjusted.
    Forshoeclearanceadjustment,seesteps8and9onpage
    BR–32orstep8onpage48. (a) Removetheconsolebox.
    (b) Loosenthelocknutandturntheadjustingnutuntilthe levertraveliscorrect.
    (e) Tightenthelocknut.
    Torque:55kg–cm(48in.–Ib,5.4N–m)
    (d) Installtheconsolebox.
    MASTERCYLINDER
    [​IMG]REMOVALOFMASTERCYLINDER
    .Ga_
    130t9.13.
    t
    t kg·em(ft.lb.N,m. I:Specified (Otque
    •Non-reusable pan:
    1. DISCONNECTLEVELWARNINGSWITCH CONNECTOR
    2. TAKEOUTFLUIDWITHSYRINGE
    NOTICE:Donotletbrakefluidremainonapaintedsurface. Washitoffimmediately.
    3. DISCONNECTBRAKETUBES
    UsingSST, disconnectbraketubesfromthemastercylinder. SST09751–36011
    4. REMOVEMASTERCYLINDER
    (a) Removethethreenutsand3–wayunion. (b) Removetheclamp.
    (c) Removethemastercylinderfromthebrakebooster andremovethegasket.
    COMPONENTS
    w/oA.B.S.
    ~c.P
    ~>---Strainef
    ReservoirSetSetew ~
    17.5(1L21n..1b.1.71
    SnapRing
    w/A8.S.
    ~S~to~ppet~-8-0~,~~!!,
    I l00(7.tot f
    ~.Ga$ket
    Aeser.<Olt SetScrew
    ~c ••
    17.5111•.2...... 1.71 @-Strliner
    Reservoir
    SnapRing
    Grommet--L--_
    .G.....-~~~i'
    ~~tP
    No,2PistonandSpring:
    S¢ng
    IkQ-cm(ft·lb.N-m) I:Spe.eified tOtque
    •Hon·teusable part
    StoppetBolt
    I100(7.101I
    Mm.
    DISASSEMBLYOFMASTER CYLINDER
    1. REMOVERESERVOIR
    (a) Removethesetscrewandpulloutthereservoir. (b) Removethecapandstrainerfromthereservoir.
    2. REMOVETWOGROMMETS
    3. PLACECYLINDERINVISE
    4. REMOVEPISTONSTOPPERBOLT
    Usingascrewdriver,pushthepistonsinallthewayand removethepistonstopperboltandgasket.
    HINT:Tapethescrewdrivertipbeforeuse.
    5. REMOVETWOPISTONSANDSPRINGS
    (a) Pushinthepistonwithascrewdriverandremovethe snapringwithsnapringpliers.
    (b) RemovetheNo.1pistonandspringhand,pulling straightout,notatanangle.
    NOTICE:Ifpulledoutatanangle,thereispossibilityof damagingthecylinderbore.
    (c) Placearagandtwowoodenblocksontheworktable andlightly tap the cylinder flange against the blocks untilthepistondropsoutofthecylinder.
    HINT:Makesurethedistance(A)fromtheragtothetop
    oftheblocksisatleast100mm(3.94in.)
    [​IMG]A
    INSPECTIONOFMASTERCYLINDER COMPONENTS
    HINT:Cleanthedisassembledparts with compressed air.
    1. INSPECTCYLINDERBOREFORRUSTORSCORING
    2. INSPECTCYLINDERFORWEARORDAMAGE
    Ifnecessary,cleanorreplacethecylinder.
    w/oA.B.S. .
    wi A.S,S.
    ASSEMBLYOFMASTERCYLINDER
    (SeepageBR–10)
    1. APPLYLITHIUMSOAPBASEGLYCOLGREASETO RUBBERPARTSINDICATEDBYARROWS
    2. INSTALLTWOSPRINGSANDPISTONS
    CAUTION:Becarefulnottodamagetherubberlipson thepistons.
    (a) Insertthetwospringsandpistonsstraightin,notat
    anangle.
    NOTICE:Ifinsertatanangle,thereispossibilityofdamag- ingthecylinderbore.
    (b) Pushinthepistonwithascrewdriverandinstallthe snapringwithsnapringpliers.
    3. INSTALLPISTONSTOPPERBOLT
    Usinga screwdriver,pushthepistoninallthewayand installthe piston stopper bolt over the gasket. Torquethe bolt.
    Torque:100kg–cm(7ft–Ib,10N–m)
    4. INSTALLTWOGROMMETS
    o
    5. INSTALLRESERVOIR
    (a) Installthecapandstrainertothereservoir. (b) Pushthereservoirontothecylinder.
    (c) Installthesetscrewwhilepushingonthereservoir.
    Torque:17.5kg–cm(15.2in.–Ib,1.7N–m)
    NOTICE:Because the master cylinder and reservoir tankunionisagrommettype,thesetscrewis de- signedtonotseparatethereservoirfromthecylinder andwillnot tighten down the reservoir. Therefore, thereisaclearanceatpoint A. Do not insert washers oranequivalentwhentightening.
    BR–14
    BRAKESYSTEM
    – MasterCylinder
    [​IMG]
    INSTALLATIONOFMASTERCYLINDER
    (SeepageBR–9)
    1. CLEANOUTGROOVEONLOWERINSTALLATION SURFACEOFMASTERCYLINDER
    2. CONFIRMTHAT”UP”MARKONMASTERCYLINDER
    BOOTISINCORRECTPOSITION
    3. ADJUSTLENGTHOFBRAKEBOOSTERPUSHROD BEFOREINSTALLINGMASTERCYLINDER
    (SeepageBR–16)
    4. INSTALLMASTERCYLINDER
    Setthenewgasketandinstallthemastercylinder,clamp and3–wayuniononthebrakeboosterwiththreenuts.
    Torque:130kg–cm(9ft–Ib,13N¿m)
    5. CONNECTBRAKETUBES
    UsingSST,connect.thebraketubestothemastercylin- der.
    Torquetheunionnuts. SST09751–36011
    Torque:155kg–cm(11ft–ib,15N–m)
    6. CONNECTLEVELWARNINGSWITCHCONNECTOR
    7. FILLBRAKERESERVOIRWITHBRAKEFLUIDAND BLEEDBRAKESYSTEM
    (SeepageBR–7)
    8. CHECKFORFLUIDLEAKAGE
    9. CHECKANDADJUSTBRAKEPEDAL (SeepageBR–6)
    BRAKEBOOSTER
    [​IMG]REMOVALOFBRAKEBOOSTER
    151"1.,.)
    3-W~Union
    •GasI<..
    '301••'31
    Ikg-cm(It·lb,.N·m) I:Specffiedtorque
    •Non-reusablepart
    1. REMOVEMASTER¿CYLINDER (SeepageBR–9)
    2. DISCONNECTVACUUMHOSEFROMBRAKE
    BOOSTER
    3. REMOVEPEDALRETURNSPRING
    4. REMOVECLIPANDCLEVISPIN
    5. REMOVEBRAKEBOOSTER,GASKETANDCLEVIS
    (a) Removethefournutsandclevis.
    (b) Pulloutthebrakeboosterandgasket.
    SST
    INSTALLATIONOFBRAKEBOOSTER
    (SeepageBR–15)
    1. ADJUSTLENGTHOFBOOSTERPUSHROD
    (a) SettheSSTonthemastercylinderwiththegasket, andthenlowerthepin until its slightly touches the piston.
    SST09737–00010
    [​IMG]
    (b) Turnthe SST upside down and set it on the booster. SST49737–00010
    (c) Measuretheclearancebetweentheboosterpush
    rodandpinhead(SST).
    Clearance:0mm(0in.)
    (d) Adjusttheboosterpushrodlengthuntilthepushrod lightlytouchesthepinhead.
    2. INSTALLBRAKEBOOSTER,GASKETANDCLEVIS
    (a) Installtheclevislocknutandclevistothebrake booster.
    (b) Installthebrakeboosterandgasket.
    (c) Installandtorquetheboostermountingnuts.
    3. CONNECTCLEVISTOBRAKEPEDAL
    Inserttheclevispinintotheclevisandbrakepedal,and installthecliptotheclevispin.
    4. INSTALLPEDALRETURNSPRING
    5. INSTALLINSTRUMENTLOWERFINISHPANEL
    BRAKESYSTEM
    – BrakeBooster
    BR–17
    [​IMG]
    6. INSTALLMASTERCYLINDER (SeepageBR–14)
    7. CONNECTVACUUMHOSETOBRAKEBOOSTER
    8. FILLBRAKERESERVOIRWITHBRAKEFLUIDAND BLEEDBRAKESYSTEM
    (SeepageBR–7)
    9. CHECKFORFLUIDLEAKAGE
    10. CHECKANDADJUSTBRAKEPEDAL (SeepageBR–6)
    Checkand adjust the brake pedal, then tighten the clevis locknut.
    Torque:260kg–cm(19ft–fb,25N–m)
    11. PERFORMOPERATIONALCHECK (SeepageBR–7)
    FRONT BRAKE
    COMPONENTS
    UnionBolt
    310(22.)1)1
    B)eederPlug
    I85(74in.-Ib.'.31
    Ikg-em1ft-lb.N,m) I:SpeeiftedlorQue
    •Non-reusable part
    R_ Disc
    REPLACEMENTOFBRAKEPADS
    HINT:If a squealing noise occurs from the front brakes whiledriving,checkthepadwearindicator. If there are tracesof the indicator contacting the rotor disc, the brake padshouldbereplaced.
    [​IMG]
    1. REMOVEFRONTWHEEL
    Removethewheelandtemporarilyfastentherotordisc withthehubnuts.
    2. INSPECTPADLININGTHICKNESS
    Checkthepadthicknessthroughthecylinderinspection holeandreplacepadsifnotwithinspecification.
    Minimumthickness:1.0mm(0.039in.)
    3. REMOVECYLINDERFROMTORQUEPLATE
    (a) Removetwo installation bolts from the torque plate.
    (b) Removethebrakecylinderandsuspenditsothehose isnotstretched.
    HINT:Donotdisconnectthebrakehose.
    F.. 211Z·FEEngl
    o'wlA,B.s.
    I(~~rqa
    4. REMOVEFOLLOWINGPARTS:
    (a) Twoanti–squealsprings. (b) Twobrakepads
    (c) Two or four anti–squeal shims (d) Two pad wear indicator plates (e) Fourpadsupportplates
    FOf'2VZ·FE Engine ofwI A.B.S. P3n7
    5. CHECKROTORDISCTHICKNESS (Seestep2onpageBR–23)
    6. CHECKROTORDISCRUNOUT
    (Seestep3onpageBR–23)
    7. INSTALLPADSUPPORTPLATES
    8. INSTALLNEWPADS
    (a) Installnewpadwearindicatorplatetoinnerpad.
    NINT:Besurethearrowonthepadwearindicator plateispointinginthedirectionofthediscrotation.
    (b) (Except2VZ–FEEngineofw/A.B.S.)
    Installtheoneanti–squealshimtotheeachpad. (c) (For2VZ–FEEngineofw/A.B.S.)
    Install the two anti–squeal shims to the each pad. HINT: Apply disc brake grease to both side of the inner anti–squealshimoftheoutsidepad.
    (d) Installthepadsontoeachsupportplate. NOTICE:Donotallowoilorgreasetogetonthe rubbingface.
    (e) Installthetwoanti–squealsprings.
    [​IMG]
    ,-",IUI
    9. INSTALLCYLINDER
    (a) Drawoutasmallamountofbrakefluidfromthereser- voir.
    (b) Pressinpistonwithahammerhandleoranequiva- lent.
    HINT:Alwayschangethepadononewheelatatimeas thereisapossibilityoftheoppositepistonflyingout.
    (c) Insertthebrakecylindercarefully–sothebootis not wedged.
    (d) Installandtorquetwoinstallationbolts.
    Torque:400kg–cm(29ft–Ib,39N¿m)
    10. INSTALLFRONTWHEEL
    11. CHECKTHATFLUIDLEVELISMAXLINE
    For2VI·FE EIlfPOn
    /)AofwiA-S.s.
    '(~~Qo_
    REMOVALOFCYLINDER
    (SeepageBR–18)
    1. DISCONNECTBRAKELINE
    Removetheunionboltanddisconnectthebrakeline.Use acontainertocatchthebrakefluid.
    2. REMOVECYLINDERFROMTORQUEPLATE
    Removethetwoinstallationboltsandcylinder.
    3. REMOVEPADS
    (Seestep4onpageBR–19)
    ... ZVZ.fE
    neofwIA..8.S.
    DISASSEMBLYOFCYLINDER
    (SeepageBR–18)
    1. REMOVEFOLLOWINGPARTS:
    (a) Twoslidingbushings
    (b) Fourdustboots
    2. REMOVECYLINDERBOOTSETRINGANDCYLINDER
    BOOT
    Usingascrewdriver,removethecylinderbootsetringand cylinderboot.
    3. REMOVEPISTONFROMCYLINDER
    (a) Putapieceofclothoranequivalentbetweenthepis- tonandcylinder.
    (b) Use compressedairtoremovethepistonfromthecyl- inder.
    CAUTION:Donotplaceyourfingersinfrontofthepiston
    whenusingcompressedair.
    4. REMOVEPISTONSEALFROMBRAKECYLINDER
    Usingascrewdriver,removethepistonseal.
    BRAKESYSTEM
    – FrontBrake
    BR–23
    [​IMG]
    INSPECTIONANDREPAIROFFRONT BRAKECOMPONENTS
    1. MEASUREPADLININGTHICKNESS Standardthickness:10.0mm(0.394in.) Minimumthickness:1.0mm(0.039in.)
    Replacethepadifthethicknessislessthantheminimum
    orifitshowssignofunevenwear.
    2. MEASUREROTORDISCTHICKNESS Standardthickness:25.0mm(4.984in.) Minimumthickness:24.0mm(0.945in.)
    Ifthediscisscoredorworn,orifthicknessislessthanmini-
    mum,repairorreplacethedisc.
    3. MEASUREROTORDISCRUNOUT
    HINT:Beforemeasuringtherunout,confirmthatthefront hubbearingplayiswithinspecification.
    Measuretherotordiscrunoutat10mm(0.39in.)fromthe outeredgeoftherotordisc.
    Maximumdiscrunout:4.07mm(0.0028in.)
    Iftherunoutisgreaterthanthemaximum,inspectandad- justitfollowingtheprocedurebelow:
    Thenreplacethediscifnecessary.
    (a) Removethetorqueplatefromtheknuckle.
    (b) Removethehubnutsofthetemporarilyinstalleddisc andpullofftherotordisc.
    (c) Checkthatthehubbearingplayiswithinspecifica- tion, and replace the bearing if not within specifica- tion.(SeepageFA–7)
    (d) Installtherotordiscandmeasurethediscrunout,
    thenshifttherotordisconefifthofaturnandmeasure thediscrunout.Similarlymeasuretherunoutateach position,andselectthepositionwheretherunout is minimum.
    (e) Inthisposition,iftherunoutiswithinspecification, installthe torque plate and torque the mounting bolts.
    Torque:1,090kg–cm(79ft–Ib,107N–m)
    (f) Ifnotwithinspecification,replacetherotordisc,and repeat(d)and(e).
    ASSEMBLYOFCYLINDER
    (SeepageBR–18)
    1. APPLYLITHIUMSOAPBASEGLYCOLGREASETO PARTSINDICATEDWITHARROWS
    2. INSTALLPISTONSEALANDPISTONINCYLINDER
    3. INSTALLCYLINDERBOOTANDSETRINGIN CYLINDER
    4. INSTALLDUSTBOOTSANDSLIDINGBUSHING
    (a) Installthedustbootsintothebrakecylinder.
    (b) Insurethatthebootissecuredfirmlytothebrakecyl- indergroove.
    _11.1:,
    (c) Installthebushingintotheboots.
    (d) Insurethatthebootissecuredfirmlytothebushing groove.
    BRAKESYSTEM
    – FrontBrake
    FOf2VZ-FEEngine ofwiA.B.·S.
    [​IMG]'(gp~Q a
    ForZVl·FEEngine01wiAB.S. .3m
    INSTALLATIONOFCYLINDER
    (SeepageBR–18)
    1. INSTALLPADS
    (SeeSteps7and8onpageBR–20)
    2. INSTALLCYLINDER
    (Seestep9onpageBR–20)
    3. INSTALLFLEXIBLEHOSETOBRAKECYLINDER
    Settheflexiblehoseandnewgasketsinpositionand installtheunionbolt.
    Torque:310kg–em(22ft–Ib,30N¿nn)
    4. FILLBRAKERESERVOIRWITHBRAKEFLUIDAND BLEEDBRAKESYSTEM
    (SeepageBR–7)
    5. CHECKFORLEAKS
    REARBRAKE DrumBrake COMPONENTS
    1.'."1.'.".P.l.u.g...
    10017.lot
    In'C)eC1lon
    Plug
    o=.;:;_--Wh..,CyI_
    ,.----,Ad,usdng Shim
    [​IMG]
    I Itg..em(It·It).Nom)I:SpKifMKI torque
    •Non·ttuatblePlrt
    REMOVALOFREARBRAKE
    1. INSPECTSHOELININGTHICKNESS
    Removetheinspectionholeplug,andchecktheshoelin- ingthethicknessthroughthehole.
    Iflessthanminimum,replacetheshoes.
    2. REMOVEREARWHEEL
    3. REMOVEBRAKEDRUM
    HINT:Ifthebrakedrumcannotberemovedeasily,per- formthefollowingsteps.
    (a) Insertabentwireoranequivalentthroughthehole in the brake drum, and hold the automatic adjusting leverawayfromtheadjuster.
    (b) Usingascrewdriver,reducethebrakeshoeadjust-
    mentbyturningtheadjuster.
    4. REMOVEFRONTSHOE
    (a) UsingSST,disconnectthereturnspring. SST09703–30010
    (b) UsingSST,removetheshoehold–downspring,cups andpin.
    SST09718–00010
    (c) Disconnecttheanchorspringfromthefrontshoe andremovethefrontshoe.
    (d) Removetheanchorspringfromtherearshoe.
    M'~
    5. REMOVEREARSHOE
    (a) Using SST, remove the shoe hold–down spring, cupsandpin.
    SST09718–00010
    (b) Usingascrewdriver,disconnecttheparkingbrake. cablefromtheanchorplate.
    (c) Using pliers,disconnecttheparkingbrakecable
    fromtheleverandremovetherearshoetogether withtheadjuster.
    6. REMOVEADJUSTERFROMREARSHOE
    (a) Removetheadjustingleverspring.
    (b) Removethe adjuster together with the return spring.
    7. DISCONNECTBRAKETUBEFROMWHEELCYL- INDER
    UsingSST,disconnectthebrakeline.Useacontainerto
    catchthebrakefluid. SST09751–36011
    [​IMG]
    8. REMOVEWHEELCYLINDER
    Removethetwoboltsandthewheelcylinder.
    9. IFNECESSARY,DISASSEMBLEWHEELCYLINDER
    Removethefollowingpartsfromthewheelcylinder.
    • Twoboots
    • Twopistons
    • Twopistoncups
    • Spring_
    INSPECTIONANDREPAIROFREAR BRAKECOMPONENTS
    1. INSPECTDISASSEMBLEDPARTS
    Inspectthedisassembledpartsforwear,rustordamage.
    2. MEASUREBRAKESHOELININGTHICKNESS Standardthickness:5.0mm(0.197in.) Minimumthickness:1.0mm(0.039in.)
    Iftheshoeliningislessthanminimumorshowssignsof unevenwear,replacethebrakeshoes.
    HINT:Ifanyofthebrakeshoeshavetobereplaced,re- placealloftherearshoesinordertomaintainevenbrak-
    ing.
    3. MEASUREBRAKEDRUMINSIDEDIAMETER Standardinsidediameter:228.6mm(9.000in.) Maximuminsidediameter:230.6mm(9.079in.)
    Ifthedrumisscoredorworn,thebrakedrummaybelathed
    tothemaximuminsidediameter.
    4. INSPECTREARBRAKELININGANDDRUMFOR PROPERCONTACT
    If thecontactbetweenthebrakelininganddrumisimprop-
    er,repairtheliningwithabrakeshoegrinder,orreplace thebrakeshoeassembly.
    Shim
    5. MEASURECLEARANCEBETWEENBRAKESHOE ANDLEVER
    Usingafeelergauge,measuretheclearance.
    Standardclearance:Lessthan0.35mm(0.0138in.)
    If theclearanceisnotwithinspecification,replacetheshim withoneofthecorrectsize.
    Thickness mm (in.)
    Oeara~ 0.2 (0.008) 0..6 (0..0201
    0..3 (0..0.12) 0..6 (0.02')
    0.' (0.0.16) 0.9 co.005)
    6. IFNECESSARY,REPLACESHIM
    (a) Removetheparkingbrakelever,andinstallthecor- rectsizeshim.
    (b) InstalltheparkingbrakeleverwithanewC–washer. (c) Remeasuretheclearance.
    INSTALLATIONOFREARBRAKE
    (SeepageBR–26)
    HINT: Assemblethepartsinthecorrectdirectionas shown.
    fijght-hand rtw_
    From
    LehWheel
    ~~1(L_Y'~
    .A"""
    RightWheel
    1. ASSEMBLEWHEELCYLINDER
    (a) Applylithiumsoapbaseglycolgreasetothecups andpistonsasshown.
    (b) Assemblethewheelcylinder.
    HINT:Installinproperdirectiononly.
    • Spring
    • Twocups
    Spring Cup
    • Twopistons
    • Twoboots.
    2. INSTALLWHEELCYLINDER
    Installthewheelcylinderonthebackingplatewithtwo bolts.
    3. CONNECTBRAKETUBETOWHEELCYLINDER
    UsingSST,connectthebraketube. SST09751–36011
    Torque:155kg–crn(11ft–Ib,15N–m)
    M....
    4. APPLYHIGH TEMPERATURE GREASETO BACKING PLATEANDADJUSTER
    (a) Applyhightemperaturegreasetothebrakeshoe
    contactsurfacesasshown.
    (b) Applyhightemperaturegreasetotheadjusterbolt threadsandends.
    5. INSTALLADJUSTERONTOREARSHOE
    Setthe adjuster and return spring in place and install the adjustingleverspring.
    6. INSTALLREARSHOE
    (a) Usingpliers,connecttheparkingbrakecabletothe lever.
    (b) Passtheparkingbrakecablethroughthenotchinthe anchorplate.
    (c) Settherearshoeinplacewiththeendoftheshoe insertedinthewheelcylinderandtheotherendinthe
    anchorplate.
    (d) UsingSST,installtheshoehold–downspring,cups andpin.
    SST09718–01000
    NOTICE:Donotallowoilorgreasetogetontheru bingface.
    7. INSTALLFRONTSHOE
    (a) Installtheanchorspringbetweenthefrontandrear shoes.
    (b) Setthefrontshoeinplacewiththeendoftheshoe insertedin the wheel cylinder and the adjuster in place.
    (c) UsingSST,installtheshoehold–downspring,cups andpin.
    SST09718–00010
    (d) UsingSST,connectthereturnspring. SST09703–30010
    8. CHECKOPERATIONOFAUTOMATICADJUSTING MECHANISM
    (a) Movetheparkingbrakeleveroftherearshoeback
    andforth,asshown.Checkthattheadjusterturns.
    Iftheadjusterdoesnotturn,checkforincorrectinstallation oftherearbrakes.
    (b) Adjusttheadjusterlengthtotheshortestpossible
    amount.
    (c) Aligntheadjustingholeonthebrakedrumandlargest holeontheaxlecarrier,installthebrakedrum.
    (d) Pulltheparkingbrakeleverallthewayupuntilaclick- ingsoundcannolongerbeheard.
    9. CHECK CLEARANCEBETWEENBRAKESHOESAND DRUM
    (a) Removethebrakedrum.
    (b) Measurethe brake drum inside diameter and diame- terofthebrakeshoes.Checkthatthedifferencebe- tweenthediametersisthecorrectshoeclearance. Shoeclearance:0.6mm(0.024in.)
    Ifincorrect,checktheparkingbrakesystem.
    10. INSTALL BRAKE DRUM
    11. INSTALLREARWHEEL
    12. FILLBRAKERESERVOIRWITHBRAKEFLUIDAND BLEEDBRAKESYSTEM
    (SeepageBR–7)
    13. CHECKFORFLUIDLEAKAGE
    REARBRAKE DiscBrake
    COMPONENTS
    •Non·'lIulobl. part
    I' vg(ROto<
    HINT:If a squealing noise occurs from the brakes while driving, check the pad wear indicator. If there are traces ofthe indicator contacting the rotor disc, the brake pad shouldbereplaced.
    ) ~ PadW..,
    ~lnd"'tO< I
    Disc
    1. REMOVEREARWHEEL
    BRAKESYSTEM
    – RearBrake
    BR–35
    [​IMG]
    Minimumthickness:1.0mmI0.039in.)
    (a) Removetheinstallationboltfromthetorqueplate.
    (b) Removethebrakecylinderandsuspenditsothe hoseisnotstretched.
    (a) Twobrakepads
    (b) Fouranti–squealshims
    (c) Fourpadsupportplates
    5. CHECKROTORDISCTHICKNESS (Seestep2onpageBR–39)
    (Seestep3onpageBR–39)
    Installthefourpadsupportplates.
    8. INSTALLNEWPADS
    (a) Installthetwoanti–squealshimstotheeachpad. HINT:Applydiscbrakegreasetothebothsideoftheinner
    anti–squealshim.
    [​IMG].
    (b) Installthetwopadssothewearindicatorplateisat thebottomside.
    NOTICE:Donotallowoilorgreasetogetontherub–
    bingface.
    9. INSTALLCYLINDER
    (a) Draw outa small amount of brake fluid from the res- ervoir.
    (b) Pressin piston with a hammer handle or an equiva- lent.
    (c) Insertthebrakecylindercarefullysothebootisnot
    wedged.
    (d) Install and.torque the installation bolt.
    Torque:200kg–cm(14ft–Ib,20N–m)
    10. INSTALLREARWHEEL
    11. FILLBRAKEFLUID
    BRAKESYSTEM
    – RearBrake
    BR–37
    [​IMG]
    REMOVALOFCYLINDER
    (SeepageBR–34)
    1. DISCONNECTBRAKEHOSE
    Removetheunionboltanddisconnectthebrakehose. Useacontainertocatchthebrakefluid.
    Removetheinstallationboltandcylinder.
    3. REMOVEPADS
    (Seestep4onpageBR–35)
    (SeepageBR–34)
    1. REMOVESLIDINGBUSHINGANDDUSTBOOTS
    2. REMOVEMAINPINBOOT
    Pulloutthemainpinboot.
    3. REMOVECYLINDERBOOTSETRINGAND CYLINDERBOOT
    cylinderboot.
    4. REMOVEPISTONFROMCYLINDER
    (a) Putapieceofclothoranequivalentasshown.
    (b) Usecompressedairtoremovethepistonfromthe cylinder.
    5. REMOVEPISTONSEALFROMBRAKECYLINDER
    .1022
    2. MEASUREROTORDISCTHICKNESS Standardthickness:10.0mm(0.394in.) Minimumthickness:9.0mm(0.354in.)
    minimum,repairorreplacethedisc.
    Maximum.discrunout:0.15mm(0.0059in.)
    Iftherunoutisgreaterthanthemaximum,replacethe disc.
    HINT:Beforemeasuringtherunout,confirmthatthehub
    bearingplayiswithinspeification.
    4. IFNECESSARY,REPLACEROTORDISC
    (a) Removetheaxlecarriermountingboltandnutofup- perside.
    (b) Removethetorqueplate.
    (e) Removethehubnutsofthetemporarilyinstalleddisc andpullofftherotordisc.
    (d) Installanewrotordiscandlooselyinstallthehub
    nuts.
    (e) Installthetorqueplateandtightenthemountingbolt.
    Torque:475kg–cm(34ft–lb,47N–m)
    (f) Installtheaxlecarriermountingboltandnutofupper side.
    Torque:2,600kg–cm(188ft–lb,255N–m)
    ASSEMBLYOFCYLINDER
    (SeepageBR–34)
    1. APPLYLITHIUMSOAPBASEGLYCOLGREASETO FOLLOWINGPARTS:
    (a) Mainpinboot
    (b) Slidingbushinganddustboots
    (e) Piston,pistonsealandcylinderboot
    4. INSTALLMAINPINBOOT
    Installthemainpinbootinplace.
    5. INSTALLSLIDINGBUSHINGANDDUSTBOOTS
    (a) Installtheslidingbushinganddustbootsintothe brakecylinder.
    (b) Insurethat the boots are secured firmly to the brake
    cylindergroove.
    .MlII .Mll"
    (SeepageBR–34)
    1. INSTALLPADS
    (Seesteps7and8onpagesBR–35and36)
    2. INSTALLCYLINDER
    (Seestep9onpageBR–36)
    Settheflexiblehoseandnewgasketsinpositionand installtheunionboltandtorqueit.
    Torque:310kg–cm(22ft–ib,30N–m)
    (SeepageBR–7)
    5. CHECKFORLEAKS
    ParkingBrake
    (ForRearDiscBrake)
    COMPONENTS
    2WD(w/oA.B.S.)and4WD
    ShoeStrut
    Han.5hoe------1
    AdJu.$ler
    2WD(w/A.B.S.)
    Shoe StJ'ut
    Spring
    FrontShoe
    [​IMG]
    Ikp-<:m1f141b,N·ml :SpecifiedIOfQue
    •Non-reusable part
    ShoeHold'-CtownCup
    ShoeHokt-down SP'W19
    RotOrDisc ... on
    DISASSEMBLYOFPARKINGBRAKE
    1. REMOVEREARDISCBRAKEASSEMBLY
    (b) Removethetwomountingboltsandremovethedisc brakeassembly.
    (c) Suspendthediscbrakesothehoseisnotstretched.
    2. REMOVEROTORDISC
    HINT:Iftherotordisccannotberemovedeasily,returnthe shoeadjusteruntilthewheelturnsfreely.
    _,,..
    3. REMOVESHOERETURNSPRINGS
    [2WD(w/oA.B.S.)and4WD]
    UsingSST,removetheshoereturnsprings. SST09717–20010
    [2WD(w/A.B.S.)]
    Usingneedle–nosepliers,removetheshoereturnsprings.
    4. REMOVEFRONTSHOE,ADJUSTERANDTENSION SPRING
    (a) Slideout the front shoe and remove the shoe adjust-
    er.
    (b) Removetheshoestrutwithspring.
    (c) Disconnectthetensionspringandremovethefront shoe.
    [​IMG]
    5. REMOVEREARSHOE
    (a) Slideouttherearshoe.
    (b) Removethetensionspringfromtherearshoe.
    (c) Disconnecttheparkingbrakecablefromtheparking brakeshoelever.
    (d) Removetheshoehold–downspringcups,springs andpins.
    PARKINGBRAKECOMPONENTS
    Inspectthe disassembled parts for wear, rust or damage.
    2. MEASUREBRAKESHOELININGTHICKNESS Standardthickness:2.0mm(0.079in.) Minimumthickness:1.0mm(0.039in.)
    unevenwear,replacetheparkingbrakeshoes.
    3. MEASUREBRAKEDISCINSIDEDIAMETER Standard inside diameter: 170 mm (6.69 in.) Maximuminsidediameter:171mm(6.73in.)
    Ifthediscisscoredorworn,thebrakediscmaybelathed tothemaximuminsidediameter.
    4. INSPECTPARKINGBRAKELININGANDDISCFOR PROPERCONTACT
    Ifthecontactbetweenthebrakelininganddiscisimprop-
    5. MEASURECLEARANCEBETWEENPARKINGBRAKE SHOEANDLEVER
    Standardclearance:Lessthan0.35rnm(0.0138in.)
    Iftheclearanceisnotwithinspecification,replacethe shimwithoneofthecorrectsize.
    [​IMG]Clearance
    "'I» S1
    (a) Removetheparkingbrakelever,andinstallthecor- rectsizeshim..
    (SeepageBR–42)
    2WD(w/oA.B.S.yand4WD
    't.on.t
    Left Wheel
    Right Wheel
    2WD(w/A.B.S.)
    Fr.o.nl
    Left Wheel
    Right Wheel
    [​IMG]
    1. APPLYHIGHTEMPERATUREGREASEONBACKING PLATEASSHOWN
    Applyhightemperaturegreasetotheslidingsurfacesof
    theshoe.
    BRAKESYSTEM
    – RearBrake
    BR–47
    [​IMG]
    2. APPLYHIGHTEMPERATUREGREASETOAD- JUSTERASSHOWN
    3. CONNECTPARKINGBRAKECABLETOPARKING BRAKELEVER
    (a) Installtheshoehold–downsprings,cupsandpins.
    (b) Connecttheparkingbrakecabletotheparkingbrake leveroftherearshoe.
    4. INSTALLREARSHOE
    Slideintherearshoebetweentheshoehold–downspring cupandthebackingplate.
    NOTICE:Donotallowoilorgreasetogetontherubbing
    face.
    5. INSTALLTENSIONSPRING,FRONTSHOEAND ADJUSTER
    (a) Installthetensionspringtotherearshoe.
    (b) Installthefrontshoetothetensionspring.
    (c) Installtheadjusterbetweenthefrontandrearshoes. (d) Installtheshoestrutwithspring.
    (e) Slideinthefrontshoebetweentheshoehold–down springcupandthebackingplate.
    6. INSTALLSHOERETURNSPRINGS
    UsingSST,installthefrontreturnspringandtheninstall therearreturnspring.
    (SeepageBR–46)
    SST09718–20010
    [2WD(w/oA.B.S.)]
    Usingneedle–nosepliers,installtheshoereturn springs.
    (SeepageBR–46)
    7. INSTALLROTORDISC
    (a) Beforeinstalling,polishthediscandshoesurfaces withsandpaper.
    (b) Aligntheholeontherearaxleshaftflangeandser-
    viceholeonthedisc.
    Contract
    8. ADJUSTPARKINGBRAKESHOECLEARANCE
    (a) Temporarilyinstallthehubnuts. (b) Removetheholeplug.
    (c) Turntheadjusterandexpand the shoes until the ro- tordisclocks.
    (d) Returntheadjustereightnotches. (e) Installtheholeplug.
    9. INSTALLREARDISCBRAKEASSEMBLY
    (a) Installthediscbrakeassemblyandtorquethetwo mountingbolts.
    Torque:475kg–cm(34ft–Ib,47N–rn)
    (b) Installtheaxlecarrierboltandnutofupperside.
    Torque:2,600kg–cm(188ft–Ib,255N–m)
    [​IMG]
    BRAKESYSTEM
    – RearBrake
    BR–49
    [​IMG]
    11. SETTLINGPARKINGBRAKESHOESANDDISC
    (a) Drivethevehicleatabout50km/h(31mph)onasafe, levelanddryroad.
    (b) Withthe parking brake release button pushed in, pull ontheleverwith9kg(19.8Ib,88N)offorce.
    (c) Drivethevehicleforabout400meters(0.25mile)in
    thiscondition.
    (d) Repeatthisproceduretwoorthreetimes.
    12. RECHECKANDADJUSTPARKINGBRAKELEVER TRAVEL
    LOADSENSING PROPORTIONING VALVE(LSPV)
    COMPONENTS
    LoadSensing "'.",,0<100109V.....
    Assembly
    SST
    CHECKANDADJUSTMENTOFFLUID PRESSURE
    1. SETREARAXLELOAD
    (a) Setthevehicleunladen.
    (b) Measuretherearaxleloadandnotethevalue. (e) Settherearaxleload.
    Rearaxleload:RW+100kg(220Ib) RW:Rearaxleunladenweight
    (Measurementtakeninstep(b))
    2. INSTALLLSPVGAUGE(SST)ANDBLEEDBRAKE SYSTEM
    SST09709–29017
    [​IMG]
    100Ic.g/em2or80 kg!cm1
    3. RAISEFRONTBRAKEPRESSURETO100kg/cm2 (1,422psi,9,807kPa)OR80kg/eM2(1,138psi,7,845 kPa)ANDCHECKREARBRAKEPRESSURE
    Brakepressure: kg/cm2(psi,kPa)
    --w/-A.-B.S-.-
    Front brake
    pressure
    Rearbrake pressure
    w/oA.B.S.
    21¿¿– FE
    Others
    100 6li.9-,.,.
    (1.422.9.801) 1'931-1.122.1S.4S3-1.131)
    100 &3.1-15.7
    11.422.9.807) t9OI5-1.091,6.241- 7.$221
    eo 41.0-54.0 ".I38.7,845l CS83- 768.4.021- 5.2'96J
    HINT: The brake pedal should not be depressed twice and/or returned while setting to the specified pressure. Readthevalueofrearpressuretvvo’secondsafterad-
    justingthespecifiedfluidpressure.
    120kg/cm!Of100kg/em!
    4. RAISEFRONTBRAKEPRESSURETO120kg/cm2
    (1,705psi,11,768kPa)OR100kg/cm2(1,422psi,
    9,807kPa)ANDCHECKREARBRAKEPRESSURE Brakepressure:kg/cm2(psi,kPa)
    -w-/A-.6.-S. --
    120 13.3-8$.3
    I
    Frontbrake
    pressure
    Rear brake pressure
    w/oA.B.S.
    2VZ–FE
    Others
    (1.707.11.768) (l.0c3-1.227'.I.8$-a~
    120 71.1-84.1 (1,707.11.7613; f1.o1'-1.1N. 6.973- $.24'71
    100 48..4_61.4
    ,1,422,.9JI(7) t688 - 873.4.746- 6.02:11
    [​IMG]
    ••s",
    5. IFNECESSARY,ADJUSTFLUIDPRESSURE
    (a) Adjustthefluidpressurebychangingthespring lenght.
    Lowpressure–ShortenA Highpressure–LengthenA
    Initialsetlength:2VZ–FE167.6mm(6.598in.) Others166.9mm(6.571in.)
    HINT:1mm(0.04in.)displacementofthespringlengt changesthefluidpressureabout1.0kg/cm2(14.2psi,98 kPa).
    (b) Tightenthenuts.
    [​IMG]Torque:260kg–cm(19ft–Ib,25N–m)
    (c) Inthe event pressure cannot be adjusted by the spring length,raiseorlowerthevalvebody.
    Lowpressure–Lower
    Highpressure–Raise
    HINT:1mm(0.04in.)displacementofthevalvebody changesthefluidpressureabout7.2kg/cm2(102.4psi,
    706kPa).
    (d) Torquethenuts.
    Torque:130kg–cm(9ft–lb,13N–m)
    (e) Adjust thefluidpressurebychangingthespring lengthagain.
    Ifitcannotbeadjusted,replacethevalveassembly.
    [​IMG]
    REMOVALOFLSPV
    (SeepageBR–50)
    1. DISCONNECTBRAKETUBES
    UsingSST,disconnectthebraketubesfromthevalve body.
    SST09751–36011
    2. REMOVELSPVASSEMBLY
    (a) Removethe adjusting nut and disconnect the spring fromtherearsuspensionarm.
    (b) Removethethreemountingboltsandremovethe
    LSPVassembly.
    INSTALLATIONOFLSPV
    1. INSTALLLSPVASSEMBLY
    (a) Installthevalveassemblywiththethreemounting bolts.
    (b) Installthe adjusting bolt lock nut to the adjusting bolt andtheninstalltheadjusting bolt to the rear suspen-
    sionarmwiththeadjustingnut.
    BR–54
    BRAKESYSTEM
    – LSPV
    [​IMG]
    (c) SetspringlengthAtoinitialsetlengthandtempo- rarilytightentheadjustingboltlocknut.
    2. CONNECTBRAKETUBES
    UsingSST,connectthebraketubes. SST09751–36011
    Torque:155kg–cm(11ft–Ib,15N–m)
    3. FILLBRAKERESERVOIRWITHBRAKEFLUIDAND BLEEDBRAKESYSTEM
    (SeepageBR–7)
    4. CHECKFORFLUIDLEAKAGE
    5. CHECKANDADJUSTFLUIDPRESSURE (SeepageBR–50)
    6. REMOVESSTANDBLEEDBRAKESYSTEM
    SST09709–29017
    7. CHECKFORFLUIDLEAKAGE
    [​IMG]
    BRAKE HOSES AND TUBES DISCONNECTANDCONNECTHOSE ANDTUBE
    1. DISCONNECTNOSEANDTUBE
    (a) Disconnecttheclip.
    (b) UsingawrenchtoholdthehoseandSST,toholdthe tube,disconnectthetubeandhose.
    SST09751–36011
    2. CONNECTHOSEANDTUBE
    (a) Connectthehoseandtubebyhand.
    (b) UsingawrenchtoholdthehoseandSSTtoholdthe tube,torquetheconnection.
    SST09751–36011
    _.
    (c) Installahoseclip.
    INSPECTIONOFBRAKEHOSESAND TUBES
    1. INSPECTBRAKEHOSES
    (a) Inspectthehosefordamage,cracksorswelling. (b) Inspectthethreadsfordamage.
    _.
    2. INSPECTBRAKETUBES
    (a) Inspectthe tube for damage, cracks, dents or corro- sion.
    ANTI–LOCK BRAKE SYSTEM (A.B.S.) Description
    • TheA.B.S.isabrakesystemwhichcontrolsthewheelcylinderhydraulicpressureofallfourwheelsduring suddenbraking and braking on slippery road surfaces, preventing the wheels from locking. This A.B.S. providesthefollowingbenefits:
    (1) Enablessteeringroundanobstaclewithagreaterdegreeofcertaintyevenwhenpanicbraking. (2) Enablesstoppinginapanicbrakewhilekeepingtheeffectuponstabilityandsteerabilitytoamini-
    mum,evenoncurves.
    • The function of the A.B.S. is to help maintain directional stability and vehicle steerability on most road conditions.However,thesystemcannotpreventthevehiclefrom skidding if the cornering speed limit is exceeded.
    • The A.B.S. has a longitudinal deceleration sensor to match braking characteristics to the full–time four–
    wheeldrive.(For4WD)
    • Incaseamalfunctionoccurs,adiagnosisfunctionandfail–safesystemhavebeenadoptedfortheA.B.S. toincreaseserviceability.
    2WD(SEDAN)
    Ignition
    Front
    scu
    Fuse
    Stop Fuse
    DOMEFuse
    Brake Light
    Brake Cylindet ,-_;.o.;_--l.@--, ~
    Speed Sensor fF~~~~~
    A.S.S.
    A.8.S.
    Computer
    [​IMG]Fl MAIN
    ToStop
    Front Brake Cylinder Rear
    BrakeCytinder
    RearSpeed Sensor
    [​IMG]
    2WD (WAGON)
    StopFuse
    R••rSpeedSensor
    R..,
    StakeOtIindet
    FlMAIN
    4WD
    GAUGe
    Fu..
    R.
    FUNCTIONOFCOMPONENTS
    Component Function
    FrontSpeedSensor RearSpeedSensor DecelerationSensor(For4WD)
    ANTILOCKWarningLight
    Actuator
    Anti–lockBrakeSystemComputer
    Detectsthewheelspeedofeachoftheleftandrightfront wheels.
    Detectsthewheelspeedofeachoftheleftandrightrearwheels.
    Detectsthedecelerationspeedofthevehicleandsendsasignal’
    accordinglytotheA.6.S.computer.
    Lightsuptoalertthedriverwhentroublehasoccuredinthe
    Anti–lockBrakeSystem.
    Controlsthebrakefluidpressuretoeachdiscbrakecylinder throughsignalsfromthecomputer.
    Fromthewheelspeedsignalsfromeachsensor,itcalculates acceleration,decelerationandslipvaluesandsendssignalsto
    theactuatortocontrolbrakefluidpressure.
    [​IMG]
    LOCATIONOFSYSTEMPARTS
    WAGON
    A.B.S. Computet
    SensorRotOl'
    A.B.S."""'Ato,
    Sensor RotOl
    ReatSpeed5eflSOf
    SenSOfRotOl
    [​IMG]
    ANTILOCK Warning IJ9ttt
    --S.h...f.t.j..
    SYSTEMDIAGRAM(2WDOFSEDAN)
    r-------------,
    I c .r- I
    I ..l!:2nI-t- I
    I "'~j.!'"_!
    II I
    I I I I I
    I
    0-:
    I
    0:
    1
    I
    .1lEJ I
    :It: I
    I I
    I !
    [​IMG]
    I
    I il
    _-g
    -"0:''>':
    .c_
    It .....
    [​IMG]
    SYSTEMDIAGRAM(2WDOFWAGON)
    r-----------,
    I
    I
    II I
    SYSTEMDIAGRAM(4WD)
    r-----------,
    I
    I 1
    I
    1 ~~ •
    I j~~ _~
    M 1 ..
    -.l~i
    I II
    I I
    ~U
    '::05
    I ~ 1
    I j~ 1
    8..!~•~
    I •
    •~u
    L M., --.:::>- i0~-:¥>
    I .:
    .•.. I
    a: a-.:.
    51 I
    - "3 ••
    a•:
    I :05
    c I ~~
    ·,t:j 1
    I(.F.~.0
    91 I
    r-f gl ~ :1t.::J I
    . ~ ~I I
    • ~IfI~ 1 •
    ! ~ I
    'So ~
    MCI) •
    8-GO.~
    I
    o•
    • I -:-. I ~.~
    i.=:J
    =:;g::
    1 :05
    I I
    I
    .....~. 1
    I :1!l 1
    I I
    _-.e
    MCI)
    ~c~
    l .; I
    ~ a:U
    f-
    I * I
    '::05
    [​IMG]'---------
    r-~~
    ~.E"
    "10
    <0
    _••c
    j~'•O~
    it·~S
    ~.l!~
    WIRINGDIAGRAM(2WD)
    .0 ",I'
    _..I.l.!.
    ~s ~
    .J:~~ ~...~").
    )l'
    _RJ
    "'...... :rl§
    0: e
    :..r..j§c ..~o§c
    ..."''''0:"''''
    c3i!1.l!~
    ::E~
    8'"
    ~")<")Wlc-, "
    ~).L
    ~')(")..(ft • .:; s~~.
    s-
    G
    e
    5..,
    '0".0: ~o
    ...'.i.
    "le
    =<8
    -to- •"
    ~ .tV • t ,
    M'" "
    'II """'-
    '" "'QO"
    J
    ~ ~ 5! ~
    .Csi..go: ~
    . :r
    "s_'
    z..
    's_"
    3'" q
    C u 0: '"
    -Q
    .u
    .l! ...J ; ~ 0:
    ~:.".C.~.o
    "0
    '-_
    ,...---t~•
    "'c '" 11;
    ioili::
    g ~~
    > 0-,
    s ~~ ~i-- ¥'
    .-':2
    • ...R...
    "',~~:'.¥o:lic '9r-.-J' 0
    ,"'''' L •C
    w !2
    ::E '" G
    :> , --(. i'3
    Z
    < .'.. 0
    .u0:
    'i
    r- " ),
    :~ ... I-
    [​IMG]
    C
    ct~
    '0'-"-1 '),
    z "
    ......<:.E
    WIRINGDIAGRAM(4WD)
    L..-<>_>---+---<>->--z--,r----,1>-11t------l41'
    CONNECTORS(2WD)
    BrakeActuator
    CONNECTORA
    CONNECTORB
    CONNECTORC
    SR
    w
    CheckConnector
    FrontSpeedSensor(LH) FrontSpeedSensor(RH)
    FR
    W T
    RearSpeedSensor(LH
    RearSpeedSensor(RH
    RL+ RL- RRT RR-
    I I I
    IG GND RL- STP SFR SFL BAT T RIR- PfB W I
    ."V!
    rdo 19 1~17
    1 15 ;~ 5
    311
    [​IMG]
    30 28 2726 252" 2322 21 12 10 9 8 6
    SRL GNO
    FL-
    FR- R-
    SR
    Fl+
    FR+
    RL+
    RR.
    AST
    MR
    MT
    SRR
    CONNETORS(4WD)
    BrakeActuator
    CONNECTORA
    CONNECTORB CONNECTORC
    ..~SRT
    123
    GNO
    R-
    CheckConnector
    FrontSpeedSensor(LN) FrontSpeedSensor(RH)
    FL.
    w T
    RearSpeedSensor(LH)
    RearSpeedSensor(RH)
    DecelerationSensor
    GS+
    RL+
    Rl-
    RR+
    RR-
    GS-
    Ts Connector
    IG
    GNO
    Rl-
    PKB
    STP
    SFR
    SFl
    BAT
    T RR-
    W
    20191817
    -1615 14
    5 3 2 1
    o
    30 282262524 32221 1211109 8 6
    SRl
    GNO
    Fl-
    FR- R-
    T$
    SR
    FL.
    FR+
    Rt.
    RR+
    AST
    MR
    MT
    SRR
    ~ (ct"")O:.o
    Ol! 10.
    DiagnosisSystem
    DESCRIPTION
    Ifamalfunctionoccurs,thesystemwillidentifytheprob- lemandthecomputerwillstorethecodesforthetrouble
    items.
    1'-
    <111111111...-
    JANTHDCKI~
    "/1111111\')
    At the same time, the system informs the driver of a mal- functionviathe”ANTILOCK”warninglightinthecombina- tionmeter.
    Byturningontheignitionswitchanddisconnectingthe
    checkconnector,thetroublecanbeidentifiedbythe numberofblinks(diagnosticcode)ofthewarninglight.
    1.IghOtO.2N&1illiruw
    OFF
    Normal Code
    TroubleCod.
    Intheeventoftwocodes,thathavingthesmallestnum- ber(code)willbeidentifiedfirst.
    HINT:Thewarninglightdoesnotshowthediagnostic
    0.55j,,6S (InCaseCode23)
    0.5. 1.5s 4.0&
    llghtON
    codeswhilethevehicleisrunning.
    OfF
    2~1QI
    INITIALCHECK
    CHECK ACTUATOROPERATIONNOISE
    (a) Starttheengineanddriveataspeedover6km/h
    (4mph).
    (b) Checkthattheactuatoroperationnoiseisheard. HINT:Ainitialcheckiscarriedoutonceeachtimeafterthe enginehasbeenstartedandinitialspeedexceeds6 km/h(4mph).Therespectivefunctions,inorder,ofthe3 position solenoidandpumpmotorintheactuatorare checked.However,ifthebrakepedalisdepressed,theini- tialcheckisnotcarriedout,butisstartedafterthepedal hasbeenreleased.
    INSPECTIONOFDIAGNOSISSYSTEM
    1. INSPECTBATTERYVOLTAGE
    Inspectthatthebatteryvoltageisabout12V.
    2. CHECKTHAT WARNINGLIGHTTURNSON
    (a) Turntheignitionswitchon.
    (b) Checkthat the ”ANTILOCK” warning light turns on for
    3seconds.
    Ifnot, inspect and repair or replace the fuse, bulb and wire harness.
    3. READDIAGNOSTICCODE
    (b) Disconnectthecheckconnectorfromtheactuator.
    151Digit 2ndOight
    0.25seconds
    ON
    OFF
    0.25 second.
    1.11
    till·••
    (c) Ineventofamalfunction,4secondslaterthewarning lightwillbegintoblink.Readthenumberofblinks. (SeeDIAGNOSTICCODEonpageBR–69)
    HINT:Thefirstnumberofblinkswillequalthefirstdigit ofatwodigitdiagnosticcode.Aftera1.5second pause,the
    2ndnumberofblinkswillequalthe2ndnumberofatwo
    digitcode.Iftherearetwoormorecodes,therewillbe a2.5secondpausebetweeneach,andindicationwill beginafter4.0secondpausefromthesmallervalue andcontinueinordertolarger.
    (d) Ifthe system is operating normally (no malfunction),
    thewarninglightwillblink2timespersecond.
    (e) Repairthesystem.
    (f) Afterthemalfunctioningcomponentshasbeenre- paired,clearthediagnosticcodesstoredinthecom- puter.
    (SeepageBR–70)
    HINT:Ifyoudisconnectthebatterycablewhilerepair- ing,alldiagnosticcodesinthecomputerwillerased.
    (g) Connectthecheckconnector.
    (h) Turntheignitionswitchon,andcheckthatthe
    ”ANTILOCK”warninglightgoesoffafterthewarning lightgoesonfor3seconds.
    Code No.
    Light Pattern
    Diagnosi s
    Trouble Part
    [​IMG][​IMG][​IMG][​IMG]11 ON JLJl..
    Off
    12 .fL.JUl.
    13 ILJlJLfL
    14 .fLJlfUl.Jl_
    21 Jl.JLfl._
    22 ILfl fUL
    23 fLfLJU11L
    24 JlJL11JUUl
    31 JlJ1JLfl.
    32 nnn.nn,
    33 IUlJLfUUl._
    34 Jl..fUL.JlJlJ1f
    36 ..flJlJLJlfUl.J
    3. ~
    31 ~
    41 .fUUlJLJl...
    42 .JlJlI1.fLJ1.J1
    43 JlJLf1JLflf1.fL
    4C .JUlJ1J1......J
    &1 Jl.11..flIULJL
    !Alway.on J
    Opencircuitinsolenoidrelaycircuit
    Short circuit in solenoid relay circuit Open circuit in pump motor relay circuit Short circuit in pump motor relay circuit
    Open or short circuit in3 position solenoid of front right wheel
    Open or short circuit in3 position solenoid of front left wheel Open or short circuit in3 position solenoid of rear right wheel Open or short circuit in3 position solenoid of rear left wheel Front right wheel speed sensor signal malfunction
    Frontleftwheelspeedsensorsignalmalfunction Rear right wheel speed sensor signal malfunction Rear left wheel speed sensor signal malfunction
    Open circuit in front left or rear right wheel speed sensor
    Open circuit in front right or rear left wheel speed sensor
    Wrong both rear axle hubs
    Low battery voltage (9.5V or lower)
    Abnormally high battery voltage0 6.2V or higher) Malfunction in deceleration sensor
    Openorshortcircuitindecelerationsensor
    Pump motor of actuator locked or open circuit in pump motor circuit in actuator
    Malfunctionincomputer
    Actuatorinsidewireharness
    Solenoid relay
    Wire harness and connector of solenoid relay circuit
    Pump motor relay
    Wire harness and connector of pump motor relay circuit
    Actuator solenoid
    Wire harness and connector of actuatorsolenoidcircuit
    Speedsensor
    Sensor rotor
    Wire harness and connector of speedsensor
    Rearsensorrotors
    Battery
    Voltageregulator
    Decelerationsensor Deceleration sensor installation Wire harness and connector of deceleration sensor
    Pump motor, relay and battery
    Wire harness, connector and ground bolt or actuator pump motor circuit
    Computer
    CLEARINGOFDIAGNOSTICCODES
    CLEARDIAGNOSTICCODES
    (b) Disconnectthecheckconnectorfromactuator. HINT:Keepthevehiclestopped[vehiclespeed0km/h (0mph)].
    (c) Clearthediagnosticcodesstoredincomputerbyde- pressingthebrakepedal8ormoretimeswithin3
    seconds.
    0,26seconds
    ON
    OfF
    0.25seconds
    (d) Checkthatthewarninglightshowsthenormalcode.
    (e) Connectthecheckconnector.
    (f) Checkthatthewarninglightgoesoff.
    Troubleshooting
    Problem
    No.
    Alwayscomesonafterignitionswitchisturnedon. 1
    Brakeworking
    Doesnotcomeonfor3secondsafterignitionswitchon. 2
    Comesonandoff. 3
    Comesonwhilerunning. 1
    Brakespull. 4
    Brakinginefficient. 4
    A.6.S.operatesatordinarybraking. 4
    A.6.S.operatesjustbeforestoppingatordinarybraking. 4
    BrakepedalpulsatesabnormallywhileA.B.S.isoperating. 4
    SkiddingnoiseoccurswhileA.B.S.working. 5
    (A.B.S. works inefficiently)
    ”ANTIL4CK”warninglightcomeson.
    Disconnectcheckconnector. (SeepageBR–68)
    Doeswarninglightalwayscomeonorshow NO
    thenormalcode?
    (ignitionswitchon)
    Seediagnosticcode. (SeepageBR–69)
    YES
    Continuedonpage
    BR–72.
    Continuedfrompage
    BR–71.
    Isconnectorofcomputerproperlyconnected? NO
    Andareallterminalsintheconnector?
    Faultyconnector.
    YES
    Isthere10–16VbetweenterminalIGon computerwireharnesssideconnectorand
    bodyground?(ignitionswitchon)
    NO Faultypowercircuit.
    YES
    Doeswarninglightgooffwhenboththecom- puterconnectorandcheckconnectorare
    ..disconnected?(Ignitionswitchon)
    YES
    (Goesoff¿
    NO
    (Comeon)
    Shortcircuitinwireharnessbetween computerterminalWandactuatorter- minalW.
    Faultycomputer.
    ”ANTILOCK”warninglightdoesnotcomeonfor3secondsafterignitionswitchon.
    Disconnect check connector from actuator, and ground the terminal W of the wire har- nesssideconnector.
    (Ignitionswitchon)
    Doeswarninglightcomeon?
    YES
    NO Bulbburnedoutoropencircuitinwire harnessbetweenwarninglightandac-
    tuatorterminalW.
    Disconnectconnectorsfromcomputerandac- tuator,andgroundterminalWofcomputerwire harnesssideconnector.
    (Ignitionswitchon)
    I ON
    Opencircuitinwireharnessbetween computerterminalWandwarninglight.
    YES
    Withignitionswitchoff,disconnectactuator connectors,andcheckcontinuitybetweenter-
    minalWandASTonactuatorside.
    Reversetesterleadsandcheckagain.
    Isthereonewaycontinuitybetweenterminals?
    YES Faultycomputer.
    NO Shortcircuitinactuatorinsidediode.
    HINT:Ifthediodeisshort–circuited,amal- functionatcomputerterminalWwilloccur. Wheninspectingtheterminal,connectthe computerconnector,anddisconnectactua- torconnectors.Thenturntheignitionswitch on,andcheckthatthewarningfightgoes on.Ifitdoes,thecomputerterminalisOK.
    ”ANTILOCK”warninglightcomesonandoff.
    • Checkconnectorisdisconnected.
    • OpencircuitinwireharnessbetweencomputerterminalTandactuatorterminalT.
    • ActuatorterminalGNDisimproperlyconnectedoropencircuitinwireharnessbetweenactuator terminalGNDandbodyground.
    • ConnectcircuitinwireharnessbetweencomputerterminalTsandTsconnector.(For4WD)
    • Brakespull.
    • Brakinginefficient.
    4 • A.B.S.operatesatordinarybraking.
    • A.B.S.operatesjustbeforestoppingatordinarybraking.
    • BrakepedalpulsatesabnormallywhileA.B.S.working.
    Doeswarninglightshowthediagnostic normalcode?(Ignitionswitchon)
    NO Seediagnosticcode. (SeepageBR–69)
    YES
    Areeachspeedsensorsinstalledinplace? Andareeachinstallationboltstightenedse-
    curely?
    NO Speedsensorinstallationfaulty.
    YES
    Disconnectconnectorfromcomputer, inspect continuity between each speed sensor termi- nalsonwireharnessside.
    (SeepageBR–103)
    ContinuedonpageBR–75
    ContinuedonpageBR–74
    DoesanyabnormalchangeoccurincontinuityYES
    whentheconnectorsorwireharnessofthe
    (Abnormal
    Faultywireharness.
    speedsensorandintermediateconnectorsarechange) I
    twistedorbent?
    NO
    (Nochange)
    Isthereforeignmaterialorferricchipsonthe sensortip?
    YES
    Cleanchipsfromthespeedsensor.
    NO
    Tryspeedsensordiagnosissystem. IssensorsignallevelOK?
    (SeepageBR–70)
    NO Inspectspeedsensor,andreplaceif necessary.
    YES
    Tryspeedsensordiagnosissystem. IssensorsignalchangeOK?
    (SeepageBR–70)
    NO Inspectsensorrotor,andreplaceif necessary.
    YES
    (For4WD)
    Trydecelerationsensoroperationdiagno- sissystem.
    IssensoroperationOK?
    (SeepageBR–82)
    NO Faultydecelerationsensoror sensorinstallationfaulty.
    YES
    Inspecttheactuatoroperation. (SeepageBR–84)
    IsactuatoroperationOK?
    I NO
    Faultyactuator.
    YES
    Faultycomputer.
    Anti–lockbrakesystemworksinefficiently.
    Doeswarninglightshowthediagnostic normalcode?(ignitionswitchon)
    (SeepageBR–69)
    YES
    Istherebatteryvoltagebetweencomput- erterminalSTPandbodygroundwhen
    depressingbrakepedal?
    NO Opencircuitinstoplightswitchand/or wireharness.
    YES
    Inspectactuator. (SeepageBR–84)
    SpeedSensorDiagnosisSystem
    PRECAUTION
    Whilecheckingthespeedsensordiagnosissystem, A.B.S.doesnotworkandbrakesystemworksasnormal brakesystem.
    (b) Checkthatthe”ANTILOCK”warninglightturnsonfor
    3seconds.
    Ifnot,inspectandrepairorreplacethefuse,bulbandwire harness.
    (c) Checkthatthe”ANTILOCK”warninglightturnsoff. (d) Turntheignitionswitchoff.
    3. PERFORMFOLLOWINGSTEPS (2WD)
    (a) Disconnectthecheckconnectorfromtheactuator.
    (b) Pullthe parking brake lever up, and start the engine.
    (c) Depressthebrakepedal4to6timeswithin2 seconds.
    [​IMG]
    0,12 seconds
    - I--
    ON nnrn r r-
    OFF -f-
    0.12seconds
    81111166
    (d) Checkthatthewarninglightblinksabout4timesev- ery1secondasshown.
    (4WD)
    (a) RemovetherubbercapfromtheTsconnectorlo- catedinfrontoftheactuator.
    (b) ConnecttheterminalsofTsconnector.
    (c) Pullthe parking brake lever up, and start the engine.
    NOTICE:Donotdepressthebrakepedal.
    o.,2$4)cond$
    ON
    OFF
    -j
    0.12seconds
    - 3.7mph)
    §@(r~
    Light Checkcompleted
    ON
    4. INSPECTSENSORSIGNALLEVEL
    Drivethevehiclestraightaheadatabout4–6km/h(2.5
    –3.7mph),andcheckthatthewarninglightturnsonafter a1secondpause.
    Ifthe warning light turns on without blinking when the ve- hiclespeedisnotwithinthespecifiedspeedrangeabove, stopthevehicleandreadthediagnosticcode,and repair themalfunctioningparts.
    (SeestepSonpageBR–79)
    HINT:Ifthewarninglightturnsonwhilethevehiclespeed iswithinspecifiedspeedrangeabove,thecheckiscom- pleted.Andwhenthevehiclespeedexceeds6km/h (3.7mph),thewarninglightwillblinkagain.Inthiscondi- tion,speedsensorsareOK.
    NOTICE:While the warning light is off, do not give any shocksto vehicle such as acceleration, deceleration, brak- ing,shift change, steering or shocks from the roadcondi- tion.
    55kmlh
    - 34.2mP'>:l/o) ..........
    5. INSPECTSENSORSIGNALCHANGE
    [​IMG]Drivethevehiclestraightaheadatabout45–55krn/h (28.0– 34.2 mph), and check that the warning light turns onaftera1secondpause.
    Ifthewarninglightturnsonwithoutblinkingwhentheve- hiclespeedisnotwithinthespecifiedspeedrangeabove, stopthevehicleandreadthediagnosticcode,andrepair themalfunctioning.parts.
    (Seestep6onthispage)
    HINT:Ifthewarninglightturnsonwhilethevehiclespeed is within specified speed range above, the check is com- pleted.Andwhenthevehiclespeedisnotwithinspecified speedrange,thewarninglightwillblinkagain.Inthiscon- dition,sensorrotorsareOK.
    NOTICE:While the warning light is off, do not give any shocks tovehiclesuchasacceleration,deceleration,brak- ing,shiftchange,steeringorshocksfromtheroadcondi-
    tion.
    6. READDIAGNOSTICCODE
    Stopthevehicleanddisconnectthecheckconnector,and warninglight will begin to blink. Read the number of blinks.
    (SeeDIAGNOSTICCODEonpageBR–81)
    ON Nannal <:<>do
    Ugh!
    OfF"n·nn·.n.n·n·nonnin"n2nn"n;n~nni(r2.•
    g~JUUUUlIlf~ 72)
    Ugh! TroubleCode
    III 7 -1-121 I
    0.5s 0.5. 1,5s 2.5or4.0,......
    ofatwodigitdiagnosticcode.Aftera1.5secondpause, the2ndnumberofblinkswillequalthe2ndnumberofa twodigitcode.Iftherearetwoormorecodes,therewill bea2.5secondpausebetweeneachcode,andthen indicationwillbeginagainaftera4.0secondpause, continuinginorderfromthesmallervalueuptothelarg- erone.
    7. REPAIRMALFUNCTIONINGPARTS
    Repairorreplacethemalfunctioningparts.
    HINT:Whenrepairingorreplacingparts,turntheignition switchOFF.
    BR–80
    BRAKESYSTEM
    – Anti–lockBrakeSystem(A.B.S.)
    [​IMG]
    8. PERFORMFOLLOWINGSTEPS
    (a) (2WD)
    Turntheignitionswitchon. (4WD)
    (b) Connectthecheckconnector.
    (For4WD)
    (c) RemovetheshortpinorwirefromtheTsconnector andinstalltherubbercaptoit.
    DIAGNOSTICCODE
    CodeNo.
    LightPattern Diagnosis
    MalfunctioningPart
    ON annnnnnnnnnnnnn
    OfF JUUUUUUUUUUUUUUl
    Allspeedsensorsandsensorrotorsarenormal
    71 Jl.fUUUUULlL
    72
    73
    74
    75
    76
    Lowvoltageoffrontrightspeedsensorsignal
    Lowvoltageoffrontleftspeedsensorsignal
    Lowvoltageofrearrightspeedsensorsignal
    Lowvoltageofrearleftspeedsensorsignal
    Abnormal change of front right speed sensor signal
    Abnormal change of front left speed sensor signal
    • Front right speed sensor
    • Sensorinstallation
    • Front left speed sensor
    • Rearrightspeedsensor
    • Rearleftspeedsensor
    • Frontrightsensor rotor
    • Frontleft sensor rotor
    Abnormal change of rear right speed sensor signal
    • Rear rightsensor rotor
    [​IMG][​IMG][​IMG]Abnormal change of rear left speed sensor signal
    • Rearleftsensor rotor
    t§'~t>.~
    I"if .~~
    AJIll
    1'- <::\1\1111L1C1l1(I/(.I)::
    \;!itl"11I"'); _,_
    Wam.,g
    Ught Engine Start
    DecelerationSensorOperation DiagnosisSystem(For4WD) PRECAUTION
    Whilecheckingthedecelerationsensordiagnosis system,A.B.S.doesnotworkandbrakesystemworksas normalbrakesystem.
    3seconds.
    (e) Checkthatthe”ANTILOCK”warninglightturnsoff.
    (c) Pull theparkingbrakeleverupanddepressthebrake pedal,andstarttheengine.
    (d) Checkthatthewarninglightblinksabout1timeevery
    1secondasshown.
    If thewarninglightdoesnotblink,inspecttheparkingbrake switch,stoplightswitch,Ts connector, deceleration sensor
    [​IMG]ON OFF-
    nAn n
    1-11-
    3. 0.8850.125
    installationandcomputer.
    4. INSPECTSENSORDETECTIONPOINT
    (a) Jackuptherearsideofthevehicle slowly as shown. HINT: When measuring the height, measure at the center oftherearbumperloweredge.
    (b) Checkthatthewarninglightdoesnotturnon.
    (c) Jackdownthevehicleandcheckthatthewarning lightblinking.
    w/o Spoiler6S == 3em(28.8:t '.2 in.)
    wI Spoiler6S:t 3em425.8:t 1.2inJ
    (d) Jackupthefrontsideofthevehicleslowlyasshown. HINT:When measuring the height, measure at the center ofthelowerbodyorspoileredgeofthevehicle.
    (e) Checkthatthewarninglightdoesnotturnon.
    (f) Jackdownthevehicleandcheckthatthewarning lightblinking.
    Ifthewarninglightturnson,inspectthedecelerationse
    sorinstallation.Andifthesensorinstallationis–OK,r placethedecelerationsensor.
    Wlming
    Ugh!
    ON
    0.12.
    5. INSPECTSENSOROPERATION
    (a) Drivethevehiclestraightaheadatabout10km/hl6.2 mph)ormore,lightlydepressthebrakepedal.
    (b) Checkthatthereisnochangeinthewarninglight
    lightpattern.
    OF_F-!l..-!I_Jl..-lI _
    W.ming Braking
    Ugh!
    ~~Fn n fl i=::jl fl fl
    Warning
    light
    ON
    _,
    _,~
    (c) Drivethevehiclestraightaheadatabout20km/h (12.4mph)ormore,depressthebrakepedala little strong.
    (d) Checkthatthewarninglightturnsonwhilebraking.
    (e) Drivethevehiclestraightaheadatabout20km/h (12.4mph)ormore,depressthebrakepedalstrong– ly.
    (f) Checkthat the warning light light pattern changes af- terbrakingasshown.
    If theoperationisnotasspecified,inspectthedeceleration sensorinstallation.AndifthesensorinstallationisOK,r placethedecelerationsensor.
    6. REMOVESHORTPIN
    (a) Stoptheengine.
    (b) RemovetheshortpinorwirefromtheTsconnector. (c) InstalltherubbercaptotheTsconnector.
    A.B.S.Actuator
    COMPONENTS
    'J..WavUnion
    MotorRttay
    11Ofl2.11l
    116111,15)
    HOld"'~~
    Cushion ~
    BrakeTube
    _-----
    155111.15) "
    630(3'.52.1
    AcluatorSr.dtet
    WAGON
    [​IMG]: SpecifiedtOfqU.
    INSPECTIONOFA.B.S.ACTUATOR OPERATION
    Batteryvoltage:10–14.5V
    2. DISCONNECTCONNECTORSFROMACTUATOR
    Disconnectthethreeconnectorsfromtheactuatoras shown.
    ...-_..
    To8Ody-e: :
    Sub-wire Harness(SST) ••311
    ""1'11T1OY,_O~TA
    ....:TUIItOll Ct«;I«JIr-=::71
    --_- --.
    r!~]=-@
    0-60
    --"-"S-"E'.-i]
    3. CONNECTACTUATORCHECKER(SST)TO ACTUATOR
    (a) Connecttheactuatorchecker(SST)totheactuator
    andbodysidewireharnessthroughthesub–wire harness(SST)asshown.
    SST09990–00150
    (b) Connecttheredcableofthecheckertothebattery positivei±yterminalandblacktothenegative(–¿ter- minal.Connect the black cable of the sub–wire har- nessto the battery negative (–) terminal or body ground.
    (c) Placethe”SHEETA”(SST)ontheactuatorchecker.
    SST09990–00163
    4. INSPECTBRAKEACTUATOROPERATION
    (a) Starttheengine,andrunitatidle.
    (b) Turntheselectorswitchoftheactuatorcheckerto
    ”FRONTRH”position.
    (c) PushandholdintheMOTORswitchforafewsec- onds.
    (d) Depressthebrakepedalandholdituntilthestep1gf
    iscompleted.
    (e) PushthePOWERSWITCH,andcheckthatthe brakepedaldoesnotgodown.
    NOTICE:DonotkeepthePOWERSWITCHpushingmore than10seconds.
    (f) Releasetheswitch,andcheckthatthepedalgoes
    down.
    ....".."_"'--
    (g) PushandholdintheMOTORswitchforafewsec- onds,andcheckthatthepedalreturns.
    (h) Releasethebrakepedal.
    "--fi!E])
    :.1:.0
    ~-~-~--O-
    -!O-~_
    --!iElij
    o
    ···-1T'.O...'IO_T-A....
    0 -@
    _A~
    (i) PushandholdintheMOTORswitchforafewsec- onds.
    (j) Depressthebrakepedalandholditforabout15
    seconds.Asyouholdthepedaldown,pushthe MOTORswitchforafewseconds.Checkthatthe brakepedaldoesnotpulsate.
    5. INSPECTFOROTHERWHEELS
    (a) Turntheselectorswitchto”FRONTLH”position.
    (b) Repeating(c)to(j)ofthestep4,checktheactuator operationsimilarly.
    (c) Similarly,inspect”REARRH”and”REARLH”posi-
    tion.
    REAR LHswitchinsteadofthePOWERSWITCH,andyou
    _. -~0
    HINT:Wheninspecting”REARLH”position,pushthe
    caninspectinanytheselectorswitchposition.
    ••'Il'T..oYOTA......
    ac"NftIIoc:aa~
    -0_.-~0
    ..",ll
    6. PUSHMOTORSWITCH
    PushandholdintheMOTORswitchforafewseconds.
    [​IMG]
    7. DISCONNECTACTUATORCHECKER(SST)FROM ACTUATOR
    (a) Removethe”SHEETA”(SST)anddisconnecttheac-
    tuatorchecker(SST)andsub–wireharness(SST)
    fromtheactuator.
    SST 09990–00150 and 09990–00163 (b) Connect the actuator connectors. (e) Clearthediagnosticcodes.
    (SeepageBR–70)
    BRAKESYSTEM
    BR–87
    [​IMG]
    REMOVALOFBRAKEACTUATOR
    1. TAKEOUTFLUIDWITHSYRINGEORAN EQUIVALENT
    CAUTION:Donotletbrakefluidremainonapainted
    surface.Washitoffimmediately.
    2. DISCONNECTACTUATORCONNECTORS
    Disconnectthethreeconnectorsfromtheactuator.
    3. REMOVEACTUATOR
    (a) UsingSST,disconnectthesixbraketubesfromthe actuatorasshown.
    SST09751–36011
    (b) Removethe three nuts, wave washers and washers. (c) Removetheactuatorfromtheactuatorbracket.
    4. REMOVETHREEHOLDERSANDCUSHIONS
    Removethethreeholdersandcushions.
    BR–88
    BRAKESYSTEM
    [​IMG]
    6. REMOVECONTROLRELAYS
    (a) Removetheconnectorfromthewireharnessclarnp. (b) Removethescrewandremovethewireharness
    clamp.
    (e) Removetherelaycase.
    (d) Removetherelaycapfromthecontrolrelays.
    (e) Removethetwocontrolrelaysfromtheactuator.
    6. REMOVEBRAKETUBES (w/oLSPV)
    UsingSST,removethefivebraketubesfromtheactuator.
    SST09751–36011
    (w/LSPV)
    UsingSST,removethefourbraketubesfromactuator. SST09751–36011
    7. REMOVEPROPORTIONINGVALVEORTHREE–WAY UNION
    (w/oLSPV)
    (a) Removethetwoboltandremovetheproportioning valvefromtheactuator.
    (b) Removetheboltandremovethevalvebracket.
    BRAKESYSTEM
    BR–89
    [​IMG]
    (w/LSPV)
    Removethetwoboltsandremovethethree–wayunion fromtheactuator.
    8. REMOVETHREE–WAYUNION
    Removetheboltandthree–wayunion.
    INSTALLATIONOFBRAKEACTUATOR
    1. TEMPORARILYINSTALLFOLLOWINGPARTS
    (a) Temporarilyinstallthethree–wayunionwithabolt.
    (w/oLSPV)
    (b) Usingaproportioningvalveinstallationbolt,install thevalvebracketinplaceandtightenthebolt.
    Torque:90kg–cm(78in.–Ib,8.8N–m)
    (c) Removetheproportioningvalveinstallationbolt. (d) Temporarilyinstalltheproportioningvalve.
    (w/LSPV)
    Temporarilyinstallthethree–wayunion.
    BR–90
    BRAKESYSTEM
    w/o LSPV
    wiLSPV
    (e) Temporarilyinstallthefiveorfourbraketubesas shown.
    [​IMG]
    2. TIGHTENFOLLOWINGPARTS
    (a) Tightenthethree–wayunioninstallationbolt.
    Torque:160kg–cm(12ft–lb,16N–m)
    (b) (w/oLSPV)
    Tightenthetwoproportioningvalveinstallationbolts.
    Torque:90kg–cm(78in.–Ib,8.8N–m) (w/LSPV)
    Tightenthetwothree–wayunioninstallationbolts.
    (c) UsingSST,tightenthefiveorfourbraketubes. SST09751–36011
    BRAKESYSTEM
    BR–91
    [​IMG]
    3. INSTALLCONTROLRELAYS
    (a) Installthetwocontrolrelaysinposition.
    (b) Installtherelaycapontothecontrolrelays.
    (c) Installtherelaycase.
    (d) Installthewireharnessclampwithascrew.
    4. INSTALLTHREECUSHIONSANDHOLDERS
    Installthethreecushionstoholdersandinstallthemtothe actuator.
    5. INSTALLCONNECTORTOCLAMP
    Installtheconnectortothewireharnessclamp.
    BR–92
    BRAKESYSTEM
    [​IMG]
    6. INSTALL ACTUATOR
    (a) Installtheactuatortotheactuatorbracketinplace. (b) Installthewashers,wavewashersandnuts.
    (e) Tightenthethreenuts.
    Torque:55kg–cm(48in.–Ib,5.4N¿rn)
    HINT:Beforeinstallingthefrontrightsidenut,installthemotor ground terminal between the plate washer and spring washer.
    (d) UsingSST,connectthesixbraketubestotheactua- tor.
    SST09751–36011
    7. CONNECTACTUATORCONNECTORS
    (a) Connectthethreeconnectorstotheactuator. (b) Bendthewireharnessclampasshown.
    10. CHECK ACTUATOROPERATION (SeepageBR–84)
    ControlRelays
    INSPECTIONOFCONTROLRELAYS
    1. REMOVECONTROLRELAYS
    5 •
    (eu,.
    NoContinuity
    o
    2. INSPECTPUMPMOTORRELAYCONTINUITY
    (a) Checkthatthereiscontinuitybetweenterminals1 and2.
    (b) Checkthatthereisnocontinuitybetweenterminals
    3and4.
    (c) Checkthatthereisnocontinuitybetweenterminals
    1and4.
    Ifcontinuityisnotasspecified,replacetherelay.
    3. INSPECTPUMPMOTORRELAYOPERATION
    (a) Applybatteryvoltagetoterminals1and2.
    (b) Checkthatthereiscontinuitybetweenterminals3 and4.
    1and4.
    Ifoperationisnotasspecified,replacetherelay.
    4. INSPECTSOLENOIDRELAYCONTINUITY
    (a) Checkthatthereiscontinuitybetweenterminals1 and3.
    (b) Checkthatthereiscontinuitybetweenterminals2 and4.
    (c) Checkthatthereisnocontinuitybetweenterminals4 and5.
    8(Q01~
    NOContinuity
    5. INSPECTSOLENOIDRELAYOPERATION
    (a) Applybatteryvoltagetoterminals1and3.
    (b) Checkthatthereiscontinuitybetweenterminals4 and5.
    (c) Checkthat there is no continuity between terminals2 and4.
    6. INSTALLTWOCONTROLRELAYS
    80_7.
    FrontSpeedSensor
    LHFront
    S.,ted$tnSOC'
    RHFront
    SpeedSentof'
    INSPECTIONOFFRONTSPEED SENSOR
    1. INSPECTSPEEDSENSOR
    .II2't"IUI
    [​IMG](a) Removetheboltfromthepipeclampofthewirehar–
    ness.
    (b) Disconnectthespeedsensorconnector.
    (e) Measuretheresistancebetweenterminals.
    Resistance:0.85–1.30K
    Ifresistancevalueisnotasspecified,replacethesensor. (d) Checkthatthereisnocontinuitybetweeneachtermi-
    nalandsensorbody.
    Ifthereiscontinuity,replacethesensor.
    (e) Connectthespeedsensorconnector.
    NO (f) Installtheboltofthepipeclamp.
    2. INSPECTSENSORINSTALLATION
    Checkthatthesensorinstallationboltistightenedprop- erly.Ifnot,tightenthebolt.
    Torque:80kg–cm(69in.–Ib,7.8N–m)
    3. VISUALLYINSPECTSENSORROTORSERRATIONS
    (a) Removethetwoboltsandremovethetorqueplate withbrakecylinder.
    (b) Removetherotordisc.
    (c) Inspectthesensorrotorserrationsforscratches, cracks,warpingormissingteeth.
    (d) Installtherotordiscandbrakecylinderassembly
    withtwobolts.
    Torque:
    2WD960kg–cm(69ft–ib,94N–m)
    4WD1,090kg–cm(79ft–Ib,107N–m)
    NOTICE:Topreventdamagetotheserrations,donotstrike theaxlehub.
    0.1.'
    INSPECTIONOF FRONT SPEED SENSOR AND SENSOR ROTOR SERRATIONS (REFERENCE) INSPECTFRONTSPEEDSENSORANDSENSORROTOR
    SERRATIONSBYUSINGANOSCILLOSCOPE
    (a) Connectan oscilloscope to the speed sensor connec- tor.
    (b) Runthevehicleat20km/h(12.4mph),andinspect speedsensoroutputwave.
    (c) CheckthatCis0.5Vormore.
    Ifnotasspecified,replacethespeedsensor. (d) CheckthatBis70%ormoreofA.
    Itnotasspecified,replacethesensorrotor.
    RearSpeedSensor(2WD)
    IOCU~7."
    RearSpeed Sensor ~ Bac:kin9Pratewith
    Parking BrakeA$$embty
    o ·O·Ring
    RearAxle Hub
    ROfot Disc:
    Ikg.em(h·l.b.N·m)I:Specifiedtorque
    •Non·reu$8ble part
    INSPECTIONOFREARSPEED
    lH Rear
    Speed Sensor
    RHRear
    SpeedSeO$O<
    SENSOR
    (a) Removetheseatcushion.
    RL+
    NoContinuity
    o
    at-RR+ RR-
    Resistance:0.85–1.50k
    (d) Checkthatthereisnocontinuitybetweeneach ter- minalandsensorbody.
    (e) Connectthespeedsensorconnector. (f) Installtheseatcushion.
    [​IMG]
    SlI.l'SN
    Torque:80kg–cm(69in.–lb,7.8N–m)
    (c) Inspect thesensorrotorserrationsforscratches, cracks,warpingormissingteeth.
    (d) Installtherotordiscandbrakecylinderassemblywith
    twobolts.
    Torque:475kg–cm134ft–lb,47N–m)
    INSPECTIONOFREARSPEEDSENSORANDSENSOR ROTORSERRATIONS(REFERANCE)
    INSPECTREARSPEEDSENSORANDSENSOR
    ROTORSERRATIONSBYUSINGANOSCILLOSCOPE
    (a) Connectanoscilloscopetothespeedsensorconnec- tor.
    Ifnotasspecified,replacetherearaxlehub.
    [​IMG]
    REMOVALOFREARSPEEDSENSOR
    1. DISCONNECTSPEEDSENSORCONNECTOR
    (b) Disconnectthesensorconnector,andpulloutthe sensorwireharness.
    (e) Removethetwoclampboltsholdingthesensorwire harnesstothebodyandsuspensionarm.
    2. REMOVEREARBRAKEASSEMBLY
    (b) Removethetwoboltsandremovethediscbrakeas- sembly.
    3. REMOVEROTORDISC
    4. REMOVEREARAXLEHUB
    (a) Removethefouraxlehubmountingbolts. (b) Removetherearaxlehub.
    (c) Removethebackingplatewithparkingbrakeas- semblyandO–ring.
    5. REMOVESPEEDSENSOR
    Removetheboltsandremovethespeedsensorfromthe backingplate.
    BRAKESYSTEM
    BR–99
    [​IMG]
    INSTALLATIONOFREARSPEED SENSOR
    1. INSTALLSPEEDSENSOR
    Installthespeedsensortothebackingplatewithabolt.
    2. INSTALLREARAXLEHUB
    (a) Installthebackingplatewithparkingbrakeassem- blyinplace.
    (b) InstallanewO–ringtotheaxlecarrier.
    (c) Installtherearaxlehubwiththefourbolts.
    Torque:820kg–cm(59ft–Ib,80N–m)
    3. INSTALLROTORDISC
    Aligntheholeontheaxlehubandserviceholeonthe disc,andinstalltherotordisc.
    4. INSTALLREARBRAKEASSEMBLY
    Torque:475kg–cm(34ft–Ib,47N–m)
    (b) Installtheaxlecarriermountingboltandnutofupper side.
    Torque:.2,100kg–cm(152ft–lb,206N–m)
    5. CONNECTSPEEDSENSORCONNECTOR
    (a) Installthewireharnesswithclampsandboltsin place.
    (b) Insertthewireharnessconnectortoinsideoftheve- hicle,andconnecttheconnector.
    (c) Installtheseatcushion.
    RearSpeedSensor(4WD)
    Rea,'s'oe<ldS..,..,..
    StMOrRotor
    (DriveShaftl
    1'I~k9---cm-'(f"'t-""b-."N--m"'l: Specified tOC'qu.
    LHRear
    SpeedSensor
    RHRe8r
    Speed5.n$Or
    INSPECTIONOFREARSPEED SENSOR
    (a) Removetherearseatcushion.
    (c) Measuretheresistancebetweenterminals.
    RL+ RL- RR+ RR-
    NoContinuity
    o
    If resistancevalueisnotasspecified,replacethesensor.
    (d) Checkthat there is no continuity between each ter- minalandsensorbody.
    Ifthereiscontinuity,replacethesensor:
    (e) Connectthespeedsensorconnector. (f) Installtherearseatcushion.
    (a) Checkthatthesensorinstallationboltistightened properly.Ifnot,tightenthebolt.
    Torque:195kg–cm(14ft–Ib,19N–m)
    (b) Checkthatthereisnoclearancebetweenthesen- sorandrearaxlecarrierasshown.
    Ifthereisclearance,replacethesensor.
    ""1,,7.
    (a) Removethedriveshaft. (SeepageRA–21)
    (b) Inspect thesensorrotorserrationsforscratches, cracks,warpingormissingteeth.
    (c) Installthedriveshaft. (SeepageRA–26)
    thedriveshaft.
    I" '\ :,
    r-:~
    if II
    INSPECTIONOF REAR SPEED SENSOR AND SENSOR ROTOR SERRATIONS (REFERENCE) INSPECTREARSPEEDSENSORANDSENSORROTOR SERRATIONSBYUSINGANOSCILLOSCOPE
    tor.
    O~ (e) CheckthatCis0.5Vormore.
    Ifnotasspecified,replacethespeedsensor. (d) CheckthatBis60%ormoreofA.
    Ifnotasspecified,replacethereardriveshaft.
    Anti–lockBrakeSystemCircuit
    INSPECTIONOFSYSTEMCIRCUIT
    1. INSPECTSYSTEMCIRCUITWITHCONNECTOR CONNECTED
    (a) RemovetheA.B.S.computer.
    (b) Usingavoltmeterwithhighimpedance(10K /V minimum), measurethevoltageateachterminaland bodyground.
    ."V ~ ~
    I[SR
    IG SAT"NO T Al-RR- PKS $TP W SFR
    (.':d
    SRL GNO 1L+ R- FR+ FR...,~L; R- RR; AST
    T. MR SRMT pR
    TesterConnection
    SFL – Body ground
    Ignitionswitchon
    Condition Voltage
    Batteryvoltage
    TroublePart
    SFR – Body ground
    SRl – Body ground
    Ignitionswitchonand”ANTILOCK”warninglightgoeson
    Ignitionswitchon
    Ignitionswitchon
    About0V
    Batteryvoltage About0V Batteryvoltage
    About0V
    Actuator,control relays
    SRR – Body ground AST – Body ground W – Body ground
    T – Body ground
    Ignitionswitchon
    Ignitionswitchon
    Ignitionswitchon
    Checkconnectordisconnected
    Checkconnectorconnected
    Batteryvoltage About0V Batteryvoitage About0V Batteryvoltage About0V Batteryvoltage
    About0V
    ”ANTILOCK”
    warninglightbulb
    Checkconnector, computer
    Ifthecircuitisnotasspecified,checkandrepairorre- placethetroublepartshowninthetableabove.
    2. INSPECTSYSTEMCIRCUITWITHCONNECTOR DISCONNECTED
    (a) Disconnecttheconnectorsfromthecomputer,in-
    spectatthewireharnesssideconnector.
    TesterConnection
    ~ -A$T
    ChrakItem
    Resistance
    Ignition switch off
    Condition
    Voltage or
    Resistance Value
    About 6
    TroublePart
    Actuator
    Voltage
    Ignitionswitch off and brake pedal depressed
    Batteryvoltage
    Stop light switch,
    T. .. Body QtOI.Irct
    (For4WO)
    AST - Sody "round
    Continuity
    Resistance
    Ts connector shorted
    Ignition switch off
    STP..~ Qf'ouncI Continuity
    PIC8 - Bodyground Voltage
    Ignitionswitchoffandbrakepedalreturned
    IgnitionswitchonandPKBleverpulled
    Continuity
    About 0 v
    stop light
    Parking broke switch,
    Engine running and PKB lever returned
    Batteryvoltage
    levelwarningswitch
    .... -AST
    Resistance
    Ignition switch off
    About 6 0
    MT..Body around
    Continuity
    Ignition switch off
    Continuity
    SO-Me
    MR-RS
    Resistance
    Resistance
    Ignition switch off
    Ignition switch off
    65–100
    50–80
    Actuator
    No continuity
    Continuity
    About 5
    Tsconnector, wiring harness
    Wiringharness
    ..e.-_.......Continuity
    Ignition switch off
    No continuity
    Rear RH speed sensor
    Noe-BodyQI'OUnd
    T-likldy QtOUfId GHD .. Bodyorourct SAT - Bodygtour.:I
    IG- 80dyOround
    SA.- A$T
    ""$-RRe
    "e-_ .......
    "L$-Rle
    Continuity
    Continuity
    Continuity Vortege Voltage Resistance
    Resistance
    Continuity
    Resistance
    Ignition switch off
    Ignition switch off
    Ignition switch off
    Ignitionswitchon
    Ignition switch off
    Ignition switch off
    No continuity
    Continuity
    Continuity Batteryvoltage Batteryvoltage About 6
    0.85 – 1.50 k
    No continuity
    0.85 – 1.50 k
    Rear LH speed sensor
    Checkconnector, wiring harness
    Wiringharness FOGfuse ECU–IGfuse Actuator
    Rear RH speed
    sensor
    Wiringharness
    ..9-_
    fR~-FRe
    .......Continuity -
    Resistance -
    No continuity
    0.85– 1.30k fl
    Front RH speed sensor
    Fle-80dy "toWd
    R.$-FLe
    SAL - ASY
    Continuity
    Resistance
    Resistance
    Ignition switch off
    No continuity
    0.85– 1.30k
    About 6
    FrontrH speed sensor
    Actuator
    (b) Connecttheconnectors,andinstallthecomput-
    ercover.
    REMOVALANDINSTALLATIONOFA.B.S. COMPUTERANDDECELERATIONSENSOR (For4WD)
    Co,,,,,,_Bolek.'
    ---_
    A.B.S.Ccmpuw
    1. REMOVEA.B.S.COMPUTER
    (a) Removethecomputercover.
    (b) Removethefivescrewsholdingthecomputertothe computerbracket.
    (e) Pulloutthewireharnessfromtheclamponthe bracket,andpullouttheconnector from the clamp onthebracket.
    (d) Disconnectthethreeconnectors,andremovethe
    A.B.S.computer.
    2. REMOVEDECELERATIONSENSOR
    Removethetwoscrews,andremovethedeceleration sensor.
    NOTICE:Donotdrivewithoutnormalinstallationofdecel- erationsensorandcomputerassembly.
    BRAKESYSTEM
    BR–105
    [​IMG]
    3. INSTALLDECELERATIONSENSOR
    (a) Installthedecelerationsensortothebracketwiththe twoscrews.
    Torque:32.5kg–cm(28in.–Ib,3.2N–m)
    (b) Installtheconnectortotheclamponthebracket.
    (c) Checkthatthedecelerationsensorisinstalledprop- erly.
    4. INSTALLA.B.S.COMPUTER
    (a) Connectthethreeconnectorsandinsertthewirehar- nesstotheclamp.
    (b) Setthecomputerinplace,andinstallitwiththefive screws.
    (c) Installthecomputercover.
