03-E2B SERIES
WORKSHOP MANUAL
DIESEL ENGINE
KiSC issued 06, 2006 A
TO THE READER
This Workshop Manual has been prepared to provide servicing personnel withinformation on the mechanism, service and maintenance of 03-E2B series. It is dividedinto three parts, “General”, “Mechanism” and “Servicing”.
General
Information on the engine identification, the general precautions, maintenance checklist, check and maintenance and special tools are described.
Mechanism
Information on the construction and function are included. This part should beunderstood before proceeding with troubleshooting, disassembling and servicing.Refer to Diesel Engine Mechanism Workshop Manual (Code No. 9Y021-01870) forthe one which has not been described to this workshop manual.
Servicing
Information on the troubleshooting, servicing specification lists, tightening torque,checking and adjusting, disassembling and assembling, and servicing which coverprocedures, precautions, factory specifications and allowable limits.All information illustrations and specifications contained in this manual are based onthe latest product information available at the time of publication.The right is reserved to make changes in all information at any time without notice.Do to covering many models of this manual, information or picture being used havenot been specified as one model.
May 2004 © KUBOTA Corporation 2004
1
03-E2B SERIES, WSM
SAFETY INSTRUCTIONS
SAFETY INSTRUCTIONS
BEFORE SERVICING AND REPAIRING
•Read all instructions and safety instructions in thismanual and on your engine safety decals.•Clean the work area and engine.•Park the machine on a firm and level ground.•Allow the engine to cool before proceeding.•Stop the engine, and remove the key.•Disconnect the battery negative cable.•Hang a “
DO NOT OPERATE
” tag in operatorstation.
SAFETY FIRST
This symbol, the industry’s “Safety Alert Symbol”, is used throughout this manual and on labels onthe machine itself to warn of the possibility of personal injury. Read these instructions carefully.It is essential that you read the instructions and safety regulations before you attempt to repair or usethis unit.DANGER:Indicates an imminently hazardous situation which, if not avoided, will result indeath or serious injury.WARNING:Indicates a potentially hazardous situation which, if not avoided, could result indeath or serious injury.CAUTION:Indicates a potentially hazardous situation which, if not avoided, may result inminor or moderate injury.
IMPORTANT:Indicates that equipment or property damage could result if instructions are notfollowed.
NOTE:Gives helpful information.
WORKSHOP MANUAL
DIESEL ENGINE
TO THE READER
General
Mechanism
Servicing
1
03-E2B SERIES, WSM
SAFETY INSTRUCTIONS
SAFETY INSTRUCTIONS
DO NOT OPERATE
SAFETY FIRST
Download Now
Kubota 03-e2b series.txt 0203 bytes · Xem: 32
