Lỗi P0171 xe kia morning đời 2008
ngocthanh27
Bình luận: 8Lượt xem: 3,716
hyundai
Lỗi P0171 xe kia morning đời 2008 la lỗi gì cả nhà nhỉ
Possible causes
- Intake air leaks
- Faulty front heated oxygen sensor
- Ignition misfiring
- Faulty fuel injectors
- Exhaust gas leaks
- Incorrect fuel pressure
- Lack of fuel
- Faulty Mass Air Flow (MAF) sensor
- Incorrect Positive Crankcase Ventilation (PCV) hose connection
Tech notes
If the P0171 is combined with the P0174 code, it's very likely that the problem is caused by an intake leak. If there are no intake leaks, the next step is to replaced the air filter and clean the air flow meter. If the problem persist the front oxygen (O2) sensor may need to be replaced.
When is the code detected?
- Fuel injection system does not operate properly.
- The amount of mixture ratio compensation is too small. (The mixture ratio is too lean.)
Possible symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- Excessive Fuel Consumption
P0171 KIA Description
With the Air/Fuel Mixture Ratio Self-Learning Control, the actual mixture ratio can be brought closely to the theoretical mixture ratio based on the mixture ratio feedback signal from the heated oxygen sensors 1. The Engine Control Module (ECM) calculates the necessary compensation to correct the offset between the actual and the theoretical ratios.
In case the amount of the compensation value is extremely large (The actual mixture ratio is too lean.), the ECM judges the condition as the fuel injection system malfunction and light up the Malfunction Indicator Light (MIL) (2 trip detection logic).
hoanmy
XE bệnh này chưa thấy chủ thớt miêu tả cụ thể?đã làm những gì rồi?và trước khi bị bệnh tật em nó làm sao?kiểm tra lại đường nhiên liệu xem sao.chỉ biết chém mỗi vậy
mcv30
Lỗi này gần giống của ford . Chủ yếu do lọc xăng bẩn , kiểm tra giắc nối và tinh trạng đo gió . Chỉnh hỗn hợp ( nếu có )
ngocthanh27
Chào cả nhà tình trạng xe em nó nổ bình thường ko hiện tượng gì chi báo đèn chek thôi a sau khi đọc lỗi song em đã vệ sinh bu gi. Cổ hút giàn kim phun và lọc xăng cả con cảm biến map nhung song xe chạy 5 km thi lai báo chek a .sau khi tham khảo ae thi mình đã tháo con cảm biến oxy vệ sinh và cho xe chạy tiếp tạm thời chua báo chek nếu còn bị chắc phải thay cảm biến oxy cac cu a
mitmun
