Mitchell_OnDemand_5.8.2.35_2_2011_Full-Uploaded.to
test
Bình luận: 5Lượt xem: 1,424
test
Cách Crack:
Installation instructions:
1 - disconnect from the internet, the computer during the installation and activation; install and run
1 - put a checkmark in the Repair and Estimator and click Next
2 - You should see a window with information about what the program could not connect to the internet to activate. If it does not appear, so you do not turn off the computer from the Internet. Click Continue.
3 - From the dialog box, write down or remember two 5-digit numbers. This is a Computer ID number.
4 - run a-key generator "KeyGenOnDemandQ32011.exe"; enter the Computer ID; solve simple math problem and enter the answer in the form of numbers. "Russian CAPTCHA" was made in order to restrict access to key generator only for Russian-speaking Internet users; click the Generate button
5 - copy/paste serial keys from the generator to activate the window and click Next
6 - specify the path to date repair disk. Can be to an older version.
Các bước Crack mình đã trình bày và hình ảnh ở trên AE nguyên cứu và cài nha, rất đơn giản.
