Tài liệu cơ khí Một số hình cắt, mô hình thiết bị
Thảo luận trong 'Cơ khí chế tạo' bắt đầu bởi autovn, 13/4/10.
  1. autovn
    29/7/09
    978
    94
    201
    511 lít xăng
    Steam turbine
    Bơm ly tâm 1 cấp
    [​IMG]
    [​IMG]
    [​IMG]
    Steam Reciprocating Pump
    [​IMG] Rotary Gear Pump
    [​IMG]Multi-Screw Pump
    [​IMG]Rotary Vane Pump
    [​IMG]Reciprocating Compressor
    [​IMG]Screw Compressor
    [​IMG]Cut-A-Way Electric Motor
    Single Phase Induction
    [​IMG]Multi-Stage Turbine Pump
    [​IMG]Lobe Blower
    [​IMG]
    5001 Gate Valve 125# - 2” Flanged
    (Click image to show larger image)
    [​IMG]
    5002 Globe Valve 125# - 2” Flanged
    click for larger image
    5003 Swing-Check Valve 2” Flanged
    [​IMG]
    5004 Ball-Check Valve 2” Flanged
    [​IMG]
    5005 Plug Valve 2” Flanged
    [​IMG]
    5006 Ball Valve 2” Flanged
    [​IMG]
    5007 Lift-Check Valve 2” Flanged
    [​IMG]
    5008 Safety Valve 2” Flanged
    [​IMG]
    5009 Control Valve 2” Flanged
    [​IMG]
    5010 Spring-Check Valve 2” Flanged
    [​IMG]
    Heat exchanger
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Multi-Pass Floating Head
    [​IMG]
    Fixed Tube Sheet Multi-Pass
    [​IMG]
    Kettle Type Reboiler, Floating Head w/Removable Tube Bundle
    [​IMG]
    Fixed Tube Sheet Single Pass
    [​IMG]
    U-Tube Type
    [​IMG]
    Vertical Thermosyphon Reboiler
    [​IMG]
    Plate and Frame Trao đổi nhiệt dạng tấm
    Acrylic Distillation Tower (tháp chưng)
    integrated systems, instrument and process trainers, educational, training models by Bayport Training and Technical Center
