Thảo luận OBD2 Scan Tools, Software, and Useful Links
Thảo luận trong 'Điện - Điện tử' bắt đầu bởi linhautonet, 16/9/10.
  1. linhautonet
    15/10/09
    574
    62
    51
    95 lít xăng
    Scanning Software - Free:
    Scanmaster ELM v.0.4.0.0 - http://www.wgsoft.de
    Digimoto Lite - http://www.digimoto.com/
    wODB - http://www.obd2crazy.com/software.html
    ScanTool - http://www.scantool.net/?mode=browseSoftware
    OBD2Spy - http://www.obd2spy.com/
    OBD-DIAG - http://www.er-forum.de/obd-diag-dl/index.php
    EasyObdII_v2 - http://www.easyobdii.com/downloads.php
    OBD Logger - http://pages.infinit.net/jsenk/obd.htm
    Mac OSX / Linux - http://www.cs.unm.edu/~donour/cars/pyobd/
    OBD Gauge, PalmOS, Pocket PC - http://www.qcontinuum.org/obdgauge/
    Other OBD2 Scan Tools - Compare Price and Features:
    Auto Enginuity - http://www.autoenginuity.com/
    ScanTool.net - http://www.scantool.net/
    Auterra - http://www.auterraweb.com/
    AutoTap - http://www.autotap.com/
    EASE Diagnostics - http://www.obd2.com/
    OBDdiagnostics.com - http://www.obddiagnostics.com/
    Tekmate Tools - http://www.tekmatetools.com/
    mOByDic - http://www.ozenelektronik.com/
    OBD-2.com - http://www.obd-2.com/
    SK Pang Electronics - http://www.skpang.co.uk/
    ElmCan obd-2.de - http://www.obd-2.de/
    Nology PDA - http://www.nology.com/pdadyno.html
    Interesting OBD2 links and other products:
    Trouble Code Lookup - http://www.actron.com/code_lookup.php
    Trouble Code Definitions - http://www.iequus.com/support/obd2_definitions.php
    OBD2 connector location - http://www.obdclearinghouse.com/oemdb/
    Elm Electronics OBD2 Chips - http://www.elmelectronics.com/
    TunerTools.com - http://www.tunertools.com
    OBD-Codes.com - http://www.obd-codes.com
    OBD2 Crazy - http://www.werner-digital.com/obd/
    Multiplex Engineering - http://www.multiplex-engineering.com/
    Proscan - http://www.myscantool.com/
    EFILive - http://www.efilive.com/
    Trouble Code Chart - http://www.troublecodes.net/
    Custom PCM/ECM Programming - http://www.madz28.com/
    Custom TBI/TPI Chips - http://www.tbichips.com/
    Custom PCM/ECM Chips - http://www.pcmforless.com/
    LS1-Edit - http://www.carputing.com/
    HPTuners - http://www.hptuners.com/
    Sunspeed Lotus Honda conversions - http://www.sunspeed.com/OBD2.htm
    Romulator - http://secure.transtronics.com/osc/index.php
    Internet Forums:
    http://www.mp3car.com/vbulletin/
    http://www.camaroz28.com/forums/
    http://www.thirdgen.org/techboard/
    http://forums.corvetteforum.com/
    Beyond Scanning - ECU Upgrades, Uploading
    Once you have seen how your car's data looks, some people will want to upgrade or change their ECU/PCM parameters by either buying an upgraded ECU or PCM calibration, or by doing their own custom ECU calibrations.
    The simpler route, by far, is to buy a custom calibration that is already programmed for your car, whether modified or stock. We can highly recommend these very experienced sources for GM cars:
    Doing your own custom calibration takes more hardware and software, and a lot more knowledge. Good sites to get smart on chip upgrades for GM cars are at:
    Be aware that you can seriously damage your car by loading the wrong parameters into your ECU/PCM. Study up on chip upgrades very carefully before even beginning to consider doing it for yourself.
