Version: 117
Language: Multilingual
Description: Dealer diagnostic Programm cars Renault, Dacia, Samsung
Extras. Info: Works with the diagnosis Renault CAN Clip adapter, and Nissan Consult
Installation Manual
A. If you already installed the previous version (you do not need instructions), run the installation and modernization program
Two. Restart the computer
Three. For the first installation, run the crack! CAN-Reanult Clip.reg apply changes
4. When installing when asking the country to choose Russia (according to the language intrfeysa) or other countries
Five. Ustanovlibo, restart your computer
6. Then on the way to go C: \ CLIP_X91 \ Lib \ Application \ and copy the file to replace RSRWin.exe from the folder ... \ New Renault Clip \ Patch
7. start RSRWin.exe
Eight. In the illustrated box pressure: check - not - enter code 333DEF-111DEF-111DEF-222DEF-221DEF-000DEF - apply - recorded in 2020 for the year
9. Recharge, and use
ps. released if an error at startup, the archive is the substitution of another user-2 files.
Cure krakozyabrami diagnosis:
Regestry open the Registry Editor and find in it the following branch:
HKEY_LOCAL_MACHINE / SYSTEM / CurrentControlSet / Control / nls / CodePage /
In it we find the lines 1250 and 1252, click the mouse button to the right and change the value to c_1251.nls.
Then restart your computer to the last value entered into force. and everything will be ok.
Installation Manual
7. start RSRWin.exe
