vothanhtam19
Mitsubishi Automatic Transmission Service Manual (F4A41/F4A42/F4A51)
Automatic Transmission service manual for Mitsubishi F4A41/F4A42/F4A51 series contain the following sections: General Information, Specifications, transmission model table, service specifications, valve body spring identification table, special tools for servicing, transmission, oil pump, under-drive clutch and input shaft, reverse clutch and overdrive clutch, second brake, output shaft, transfer drive gear, differential, valve body, speedometer gear, drive shaft oil seal.
Download Now
Service Manual Automatic Transmission Mitsubishi.txt 0820 bytes · Xem: 60
