Tài liệu sửa chữa Sửa chữa bơm (pump repair)
Thảo luận trong 'Các vấn đề về thủy lực & ứng dụng' bắt đầu bởi autovn, 13/1/10.
  1. autovn
    29/7/09
    979
    91
    201
    499 lít xăng
    [​IMG]
    Before
    [​IMG]
    After
    [​IMG]
    24-Stage Pump Unit
    [​IMG]
    Large Vertical Pumps
    [​IMG]
    Split Case
    CÂN BẰNG ĐỘNG -Dynamic Balancing
    [​IMG]
    Large Rotating Units up to 6,000 Pounds
    [​IMG]
    Pump Impeller
    [​IMG]
    Large Mixer
    [​IMG]
    Blower Fan
    XỬ LÝ TẠI HIỆN TRƯỜNG - Field Machining
    [​IMG]
    Ring Gaskets on Large Pressure Vessels
    [​IMG]
    Field Machining of Heat Exchanger Flanges and Large Valves
    [​IMG]
    Milling Shaft Keyways
    [​IMG]
    Line Boring
    [​IMG]
    Small Flanges Down to 2"
    SỬA CHỮA BÁNH CÔNG TÁC - Impeller Repair
    [​IMG]
    Replace Worn Wear Rings · Renew Clearances
    [​IMG]
    Repair Damaged Wear Rings
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Build Up Impeller Veins
    [​IMG]
    Repair Impeller Veins
    [​IMG]
    [​IMG]
    [​IMG]
    High Service Pumps
    [​IMG]
    Emergency Repair of Gear Box
    [​IMG]
    Gear Box
    [​IMG]
    Repair of Gear Boxes
    [​IMG]
    High Speed Blowers
  2. vvn56
    25/1/12
    389
    69
    51
    412 lít xăng
  3. SonNgok
    7/3/16
    53
    1
    21
    Giới tính:
    Nam
    353 lít xăng
    cần...............THOSUAXEOTOHUI
