CLB Điện tử - Viễn thông Tài liệu Biến tần Rich Electric EI-500 Series
Thảo luận trong 'Câu lạc bộ các ngành kỹ thuật' bắt đầu bởi Escape, 24/11/10.
  1. Escape
    22/10/09
    1,123
    51
    186
    650 lít xăng
    #1 Escape, 24/11/10
    Features
    • Multiple Functions
      • 8 multi-speed settings, 8-step acceleration/deceleration time, 3 jump frequencies….etc.
      • PID control, energy savings control, speed search, auto restarting
      • Manual/Auto torque boost, DC injection braking, 150% torque at 1HZ, stall prevention
      • Remote speed reference: 0~10VDC, 4~20MA. 0~20MA, analog input, multifunctional input and output terminal, analog output monitor, NPN and PNP input signal switch.
      • Removable keypad (Able to read and write parameter)
      • RS485 serial communication port, MODBUS message format
    • Broad Application
      • Transporting Machine
        • Conveyer
        • Lifting
        • Elevator
      • Public Equipment
        • Industrial Laundry
        • Car Washing Machine
        • Running Machine
      • Flow Machine
        • Fan
        • Pump
        • Blower
      • Food Processing Machine
        • Grinder
        • Mixer
        • Stirrer
      • Printing Textile Machine
        • Printing Machine
        • Textile Machine
        • Dyer
      • Air Conditioning
        • Freezer
        • Air Conditioner
        • Air Compressor
      • Space Vector Technology (SVPWM)
        • High power factor (Low iron loss)
        • Low rising of motor temperature. (Continuous operation)
        • High voltage range (15.9%)
        • Steady and smooth operation
        • High torque
    Applications
    • Coating
    • Shaker Conveyor
    • Luggage Scanner Conveyor
    • High Speed Depalletizer
    • Multiple Motor Operation
    • Combination Motor Starter Interconnection
    • Glass Container
    • Snack Food Package Collator
    • Textile Facility Rebuild
    • Carpet Fiber Winder
    • EtherNet/IP CM092/CM093 Option with AB Controllogix / Compactlogix Programmable Controllers
    • Commissioning the CM092/CM093 EtherNet/IP Option Kit with the Rockwell BOOTP/DHCP Server
    [​IMG]
    [​IMG]
    Các file đính kèm:
