tiếng anh chuyên nghành máy công trình
Thảo luận trong 'Thảo luận về xe máy công trình' bắt đầu bởi hiepphat37, 27/5/16.
  1. hiepphat37
    13/2/16
    102
    14
    36
    Giới tính:
    Nam
    324 lít xăng
    chào các cụ.e có 1 số khó khăn về tiếng anh,tiếng anh e lại mù tịt,e dịch mấy thứ phần mềm rồi mà k chính xác, vậy hôm nay e đăng bài này mong các cụ giúp đỡ ạ.e cảm ơn các cụ nhiều Travel forward pilot port
    Travel reverse pilot port
    Optional pilot port
    Optional pilot port
    Bucket in pilot port
    Bucket out pilot port
    Boom up pilot port
    Boom down pilot port
    Arm out confluence pilot port
    Arm in confluence pilot port
    Dozer down pilot port
    Dozer up pilot port
    Swing right pilot port
    Swing left pilot port
    Arm out pilot port
    Arm in pilot port
    Pilot pressure port
    Drain port
    Drain port
    Pressure port for auto idle signal
    Drain port
    Main relief set pressure up pilot pressure port
    Pilot pressure port
    Drain port
    Drain port
    Drain port
    Drain port
    Swing logic valve pilot port
    Lock valve pilot port (arm rod side)
    Lock valve pilot port (boom head side)
    Boom up confluence pilot port
    Swing priority pilot port
    Bypass cut spool pilot port (P1 side)
    Bypass cut spool pilot port (P2 side)
    Opt P/relief set pressure up pilot pressure port
    Posi-nega pressure port (P1 side)
    Posi-nega pressure port (P2 side)
    Bucket in stroke limiter pilot port
    A
    Arm regeneration cut pilot port
    Nega-con pressure port (P1 side)
    Nega-con pressure port (P2 side)
    Arm2 logic valve pilot port
    Shuttle-swing pilot pressure port
    Shuttle-swing or arm in pressure port
    Travel forward port
    Travel reverse port
    Optional port
    Optional port
    Bucket cylinder head side port
    Bucket cylinder rod side port
    Boom cylinder head side port
    Boom cylinder rod side port
    Swing motor right port
    Swing motor left port
    Arm cylinder rod side port
    Arm cylinder head side port
    Pump port (P1 side)
    Pump port (P2 side)
    Dozer cylinder head side port
    Dozer cylinder rod side port
    Quick clamp solenoid valve supply port
    Bài viết khác:
