Tài liệu cơ khí Tổng hợp sách kỹ thuật bảo trì cho dân cơ khí
Thảo luận trong 'Cơ khí chế tạo' bắt đầu bởi TIENVY, 1/5/12.
  1. TIENVY
    10/2/11
    144
    14
    36
    392 lít xăng
    #1 TIENVY, 1/5/12
    [​IMG]
    Maintenance Fundamentals
    1/ Impact of Maintenance
    2/ Fundamental Requirements of Effective Preventive Maintenance
    3/ Designing a Preventive Maintenance Program
    4/ Planning and Scheduling
    5/ Scheduled Preventive Maintenance
    6/ Maintenance Ebgineering Roles and Responsibilities
    7/ Shaft Alignment
    8/ Rotor Balancing
    9/ Bearings
    10/ Couplings
    11/ Gears and Gearboxes
    12/ Compressors
    13/ Control Valves
    14/ Conveyors
    15/ Fans, Blowers, and Fluidizers
    16/ Dust Collectors
    17/ Pumps
    18/ Steam Traps
    19/ Performance Measurement and Management
    http://www.mediafire.com/?hn3fyc3mu29
    Pass: vinamain.com
    Machinery Component Maintenance and Repair
    Part 1: Background to Process Machinery Maintenances Programming
    Part 2: Alignment and Balacing
    Part 3: Maintenance and Repair of Machinery Components
    http://www.mediafire.com/?f22jsawy9f5
    Pass: vinamain.com
    Industrial Machinery Repair
    1/ Introduction: Why Use Best Maintenance Repair Practices ?
    2/ Fundamental Requirements of Effective Preventive/Predictive Maintenance
    3/ Maintenance Skills Assessment
    4/ Safety First, Safety Always
    5/ Rotor Balancing
    6/ Bearings
    7/ Chain Drives
    8/ Compressors
    9/ Control Valves
    10/ Conveyors
    11/ Couplings
    12/ Dust Collectors
    13/ Fans, Blowers, and Fluidizers
    14/ Gears and Gearboxes
    15/ Hydraulics
    16/ Lubrication
    17/ Machinery Installation
    18/ Mixers and Agitators
    19/ Packing and Seals
    20/ Precision Measurement
    21/ Pumps
    22/ Steam Traps
    23/ V-Belt Drives
    24/ Maintenance Welding
    http://www.mediafire.com/?cx3d8wjw6gi
    Pass: vinamain.com
    Friction, Wear, Lubrication
    1/ The State of Knowledge in Tribology
    2/ Strength and Deformation Properties of Solids
    3/ Adhesion and Cohesion Properties of Solids: Adsorption to Solids
    4/ Solid Surfaces
    5/ Contact of Nonconforming Surfaces and Temperature Rise on Sliding Surfaces
    6/ Friction
    7/ Lubrication by Inert Fluids, Greases and Solids
    8/ Wear
    9/ Lubricated Sliding-Chemical and Physical Effects
    10/ Equations for Friction and Wear
    11/ Designing for Wear Life and Frictional Performance: Wear Testing, Friction Testing and Simulation
    12/ Diagnosing Tribological Problems
    http://www.mediafire.com/?86dk8uos15h
    Handbook of Shaft Alignment
    1/ Introduction to Shaft Alignment
    2/ Detecting Misalignment on Rotating Machinery
    3/ Foundations, Baseplates, Installation and Piping Strain
    4/ Flexible and Rigid Couplings
    5/ Preliminary Alignment Checks
    6/ Shaft Alignment Measuring Tools
    7/ Correcting Misalignment
    8/ Alignment Modeling Basics
    9/ Defining Misalignment: Alignment and Coupling Tolerances
    10/ Reverse Indicator Method
    11/ Face and Rim Methods
    12/ Double Radial Method
    13/ Shaft to Coupling Spool Method
    14/ Face-Face Method
    15/ Electronic and Electro-Optical Shaft Alignment Systems
    16/ Measuring and Compensating for Off-Line to Running Machinery Movement
    17/ Aligning Multiple-Element Drive Systems
    18/ Aligning V-Belt Drives
    19/ Bore Alignment
    20/ Parallel Alignment
    21/ Alignment Considerations for Specifics Types of Machinery
    22/ The History of Machinery Alignment
    http://www.mediafire.com/?v62nu03vkes
    pass: vinamain.com
    Handbook of Lubrication
    1/ Friction, Wear and Lubrication Theory
    2/ Lubricants and Their Application
    3/ Design Principles
    http://www.mediafire.com/?5svy2oks8d2
    Pass: vinamain.com
    Hydrodynamic Lubrication
    1/ Friction, Wear, and Lubrication
    2/ Foundations of Hydrodynamic Lubrication
    3/ Fundamentals of Journal Bearings
    4/ Fundamentals of Thrust Bearings
    5/ Stability of a Rotating Shaft – Oil Whip
    6/ Foil Bearings
    7/ Squeeze Film
    8/ Heat Generation and Temperature Rise
    9/ Turbulent Lubrication
    http://ifile.it/glwsvrd
    Mechanical Engineer’s Data Handbook
    1/ Strength of materials
    2/ Applied mechanics
    3/ Thermodyanmics and heat transfer
    4/ Fluid mechanics
    5/ Manufacturing technology
    6/ Engineering materials
    7/ Engineering measurements
    8/ General data
    http://www.mediafire.com/?ro4895c1zrj619z
    Pass: vinamain.com
    Lubrication and Reliability Handbook
    1/ Lubricants
    2/ Lubrication of components
    3/ Lubrication systems
    4/ Machine operation
    5/ Machine maintenance
    6/ Component failures
    7/ Component repair
    8/ Reference data
    http://ifile.it/ae6f3k1
    Manual of Engineering Dwaring
    1/ Drawing office management and organization
    2/ Product development and computer aided design
    3/ CAD organization and applications
    4/ Principles of first and third angle orthographic projection
    5/ Linework and lettering
    6/ Three dimensional illustrations using isometric and oblique projection
    7/ Drawing layouts and simplified methods
    8/ Sections and sectional views
    9/ Geometrical constructions and tangency
    10/ Loci applications
    11/ True lengths and auxiliary views
    12/ Conic sections and interpenetration of solids
    13/ Development of patterns from sheet materials
    14/ Dimensioning principles
    15/ Screw threads and conventional representations
    16/ Nuts, bolts, screws and washers
    17/ Keys and keyways
    18/ Worked examples in machine drawing
    19/ Limits and fits
    20/ Geometrical tolerancing and datums
    21/ Application of geometrical tolerances
    22/ Maximum material and least material principles
    23/ Positional tolerancing
    24/ Cams and gears
    25/ Springs
    26/ Welding and welding symbols
    27/ Engineering diagrams
    28/ Bearings and applied technology
    29/ Engineering adhesives
    30/ Related standards
    31/ Production drawings
    32/ Drawing solutions
    http://ifile.it/co8ghxw
    Mechanical Engineering Systems
    1/ Introduction: the basis of engineering
    2/ Thermodynamics
    3/ Fluid mechanics
    4/ Dynamics
    5/ Statics
    http://ifile.it/g68o9e5
    Gearbox and Differential
    1/ Removal Refitting
    2/ Bench Disassembly
    3/ Gears
    4/ Assembly
    5/ Central Differential Unit: Distributor
    6/ Front Differential Unit: Transmission
    7/ Drive Shafts
    8/ Tightening Torques
    http://ifile.it/wcpt7eq
    Lubrication and Lubricant Selection
    1/ Basic Principles of Lubrication
    2/ Choice of Lubricant Type
    3/ Lubricating Oils
    4/ Selection of Lubricating Oil
    5/ Oil Supply Systems
    6/ Oil Changing and Oil Conservation
    7/ Greases and Anti-seizes
    8/ Dry Bearings and Solid Lubrication
    9/ Gas Bearings
    10/ Sealing of Lubricants
    11/ Lubricant Testing and Specifications
    12/ Lubricant Monitoring
    13/ Lubricant Handling and Storage
    14/ Health and Safety
    http://ifile.it/potrd06
    A Textbook of Mechanical Engineering
    http://ifile.it/cb17wqr
    Mechanical Engineering’s Handbook
    http://ifile.it/kl46p3i
    Diesel Engine Fundamentals
    http://ifile.it/ih5opjg
    Mechanical Drawing Problems
    http://ifile.it/xuqhbsm
    Manual Gearbox Design
    1/ Crown wheel and pinion
    2/ Internal running gear
    3/ Lubrication of gears
    4/ Gear tooth failures
    5/ Crown wheel and pinion designs
    6/ Oerlikon cycloid spiral bevel gear calculations
    7/ Gearbox design – rear-engined racing cars
    http://ifile.it/fd5yiq4
    What Went Wrong
    1/ Preparation for Maintenance
    2/ Modifications
    3/ Accidents Caused by Human Error
    4/ Labeling
    5/ Storage Tanks
    6/ Stacks
    7/ Leaks
    8/ Liquefied Flammable Gases
    9/ Pipe and Vessel Failures
    10/ Other Equipment
    11/ Entry to Vessels
    12/ Hazards of Common Materials
    13/ Tank Trucks and Cars
    14/ . Testing of Trips and Other Protective Systems
    15/ Static Electricity
    16/ Materials of Construction
    17/ Operating Methods
    18/ Reverse Flow and Other Unforeseen Deviations
    19/ I Didn’t Know That
    20/ Problems with Computer Control
    21/ Inherently Safer Design
    22/ Reactions-Planned and Unplanned
    http://ifile.it/e8f3lgu
    Đã được đổ xăng bởi namviethoa.
  2. anhseve.vb
    20/4/12
    7
    0
    1
    206 lít xăng
    pass bac oi?
  3. TIENVY
    10/2/11
    144
    14
    36
    392 lít xăng
    paas đây:vinamain.com
