javaro_2405
Content Inside :
After connecting all of the SupraStick wires, but before replacing the kick panels and glove box, start by turning the car’s ignition to on (do not start the car). The SupraStick unit will click twice. Select manual shifting mode. Shift up and down through the gears. You should hear a distinctive click in the SupraStick box and in the tranny for each shift. You may verify the following voltages on wires 13-15 for each gear.
Download Now
Toyota Supra MKII Installation Manual – Firmware Version 3.0.txt 0339 bytes · Xem: 76
