MEASUREMENT OF OIL LEAKAGE FROM HYDRAULIC PUMP
Bình luận: 7Lượt xem: 2,038
maxtor
Hello to all Friends
All of those items Komatsu HYDRAULIC EXCAVATOR Work Experience. Please advise me about PC340-7 Hydraulic Pump.
In normal conditions of work,In a few hours hydraulic pump should be repaired or rebuilt?
Is the shell of the pump drain hose (PT) can leak into the measured and indicated that the pump is faulty?
Thanks and regards
Ngutunguyen
Bằng lái Hạng "Vét đĩa".
Thanks and regards
Thanks for your help
Normally when it is necessary to repair the pump?
If the pump is faulty, how can it be detected?
Pump Performance Test Procedure HPV125+125_PC300(350)-7
