[0000357] Tài liệu đào tạo Hyundai Step II 2007 : Hệ thống điều hòa không khí
khoadongluc
Bình luận: 8Lượt xem: 4,559
khoadongluc
Nothing Is Impossible
Bộ tài liệu đào tạo Hyundai Step do Chonan Technical Service Training Center xuất bản đươc phát hành vào năm 2007 và mỗi năm ra phiên bản mới chúng tôi sẽ lần lượt cập nhật liên tục cho đến năm 2010 . Trong bộ Step 2 này gồm 27 phần :
4WD
A Engine
ABS TCS ESP System
AC, FATC
Actuator & Troubleshooting
AT FF (Alpha Beta)
AT FF(HIVEC)
AT FR (AISIN)
Common Rail (Bosch)
Common Rail (Delphi)
Communication
CVVT System
D Engine
Electrical Diagnosis & TS
EMS Troubleshooting
ETACS (BCM)
Gasoline Engine Mechanical
Immobilizer
Injection Pump
J Engine
Lighting system, IMS
Manual Transaxle
OBD-II, EOBD
Rain Sensor, Trip Computer
Sensor & Troubleshooting
WGT VGT
Wheel alignment & ECS
Dưới đây chúng tôi sẽ lần lượt đi từng phần
Tài liệu đào tạo Hyundai Step 2 tiếng anh 2007 : Hệ thống điều hòa không khí
Định dạng : Ppt/doc
Số trang : 549/75
Dung lượng :18 MB
Năm phát hành : 2007
HYUNDAI MOTORS
407-7, Yongdu-Ri, Byungchon-Myun, Chonan-City,
Chungnam,330-863, Korea
TEL : 82-41-559-2960 FAX : 82-41-561-0584
Content word
1. General information ························· 9 5. FATC system ································ 37
1.1 Heat transfer ············································ 9 5.1 FATC Input & output
1.2 Sensitive heat and latent heat ···················· 11 5.2 Parts location
········································ 38
1.3 Temperature and humidity ························· 11 5.3 Blower Motor speed control ···················· 38
1.4 Pressure - Temperature relationship ··········· 12 5.4 Actuators ············································· 41
2. Cooling ·········································· 15 5.5 Sensors ················································ 44
2.1 Refrigeration ············································ 15 6. FATC Control panel ······················· 53
2.2 Refrigerant ··············································· 16 6.1 FATC with AQS ······································ 53
3. Air conditioning cooling cycle ··········· 21 6.2 FATC without AQS ································· 53
3.1 Evaporation ············································· 21 6.3 Temperature unit change ························ 54
3.2 Compression ··········································· 22 6.4 Switch function ····································· 54
3.3 Condensation ··········································· 22 7. FATC Control logic ························ 57
3.4 Expansion ················································ 22 8. FATC Self diagnosis ······················ 59
4. Components of air conditioner ·········· 23 9. A/Con Diagnosis ··························· 61
4.1 Compressor ············································· 23 9.1 A/con refrigerant ··································· 61
4.2 Magnetic clutch ········································ 24 9.2 How to check & test fluorescent materials ···· 66
4.3 Safety valve (Pressure Relief Valve) ············ 24 10. A/con Trouble Shooting ················ 67
4.4 Belt lock safety function ···························· 25 10.1 Compressor does not operate ··············· 67
4.5 Condenser ··············································· 26 10.2 Blower motor does not operate ·············· 69
4.6 Receiver drier ··········································· 28 10.3 Actuators do not operate ······················ 70
4.7 Pressure switch ········································ 29 10.4 Cold air is not emitted ····························· 72
4.8 Expansion valve ······································· 32
4.9 Evaporator unit ········································ 33
4.10 Thermostat ············································· 34
4.11 Heater unit ············································· 35
4.12 Air filter ················································· 36
4.13 Blower motor assembly ··························· 36
Pass:
