Cách reset nhớt 1 số xe Mercedes-Benz
P
Bình luận: 0Lượt xem: 3,421
phamhuy
Resetting Oil Service Indicator Lights
Mercedes Benz
1998-06 All Models with Flexible Service System (FSS)
The “Wrench” symbol will appear in the odometer field. To reset, turn the ignition key to position 2. Immediately press the button next to the display twice within one second. The present status for days or distance will be displayed. Within 10 seconds, turn the ignition key to the 0 position. Press and hold the button while turning the key to position 2 again. The status for days or distance will be displayed again; continue to hold the button. After 10 seconds, a signal will sound and the display will show 10,000 miles (15 000 km). Release button.
S350 CL500 SL500 S430 CL600 SL600 S500 CL55 AMG SL55 S600
CL65 AMG SL65 AMG S65 AMG
  • Switch on ignition.
  • Press the system selection button repeatedly until the total mileage is displayed in the multifunction display.
  • Press the scroll forward/backward button repeatedly until the service symbol is displayed in the multifunction display.
  • Press and hold the reset button for 3 seconds.
  • The multifunction display will show "DO YOU WANT TO RESET THE SERVICE INTERVAL? CONFIRM WITH THE RESET BUTTON”.
  • Press reset button to confirm.
  • Switch off ignition.
C230 CLK35O R350 ML350 C280 CLK500 R500 ML500 C350 CLK55 AMG C55 AMG
  • Turn key in electronic ignition to position 1.
  • Press the system selection button repeatedly until the basic display (kilometer reading or temperature display) appears in the multifunction display.
  • Press the trip odometer reset button 3 times briefly. A signal tone sounds and the voftage display appears in the multifunction display.
  • Press lower scroll forward/back button the “Service menu” appears in the multifunction display.
  • Press buttons + and -‘ setting of specific functions and volume controls repeatedly and select ‘confirmation” menu item.
  • Press lower system selection button to confirm. “Confirmation appears in the display and the menu ftem “Complete service” is shown against a highlighting bar.
  • Press lower system selection button to confirm. “Service confirmed” appears in the display.
  • Press the upper system selection button repeatedly until the “Service Menu” is shown in the display.
  • Using the + and - buttons, setting of specific functions and volume controls, select menu item “Special work.’ Press lower system selection button to confirm.
  • Using the + and - buttons, setting of specific functions and volume controls, select menu item ‘Service 13.” Press lower system selection button to confirm.
  • Using the + and - buttons, setting of specific functions and volume controls, select the specification of the engine oil used “Standard oil” or “Oil quality 229.5.’ Press lower system selection button to confirm.
  • the message “Item confirmed” appears in the display.”
Mercedes Benz S500, S600
Turn key in ignition lock into position 1. Press and hold down OK button and right accept/terminate phone call button simultaneously for approx. 5 seconds. Select ASSYST PLUS Workshop and confirm with the OK button. Select “Service Performed’ with scroll forward/back button and confirm with OK button.
Discover Why You Should Be Treating Your Mercedes To AMSOIL
You have chosen one of the finest automotive marques in the world. Your Mercedes can only benefit from using the finest, and highest performing lubricants and fluids in the world.​
Nguồn: http://www.synthetic-direct.ca
