2008 > D 2.5 TCI-4D56 > Fuel System > Engine Control System > P1131 Fuel Quantity Adjust Resistor Circuit - Malfunction
Component Location
General Description
Compensating resistance is simple resistance. But using it, ECM adjusts fuel quantity and carries out fuel quantity correction in idle. It plays a role adjusting fuel injection quantity from the injection pump. It is classifid 13 steps form №1 to №13 based on №7. If ECM has unsuitable compensating resistance value in it, there would be poor acceleration, excessive exhaust gas.
DTC Description
This code is about compensating resistance of injection pump. This code is set when ECM detects different compensating resistance value from one in it. When installing different compensating resistance with one stored in ECM, It must be carry out to erase stored value in ECM. Vehicle can be operated normally in ECM normal condition, but in case of ECM fault, there would be poor acceleration, excessive exhaust gas. MIL doesn't work.
DTC Detecting Condition
Item Detecting Condition Possible Cause
DTC Strategy
Voltage monitoring
Open or short in sensor harness
Poor connection
Open or short in compensating resistance
ECM EEPROM fault
Enable Conditions
IG KEY "ON" or ENG. RUNNING
Case1 Threshold
Value
sensor voltage ≤ 0.1V or ≥ 4.6V
Diagnostic
Time
5 sec
Case2 Threshold Value
There is a difference between actual value and stored value in ECM
Diagnostic Time
12.75 sec
Fail Safe
Substitute with stored value in EEPROM.
Substitute with №7 in case of EEPROM fault.
Resolutive condition
When normal signal is inputted
MIL ON Condition
NO
Specification
Adjust
Resistor(№) Resistance(㏀) Adjust
Resistor(№) Resistance(㏀) deviation
№1 0.18 №6 1.1 №11 5.6 ± 5%
№2 0.3 №7 1.5 №12 8.2
№3 0.43 №8 2 №13 15
№4 0.62 №9 2.7
№5 0.82 №10 3.9
Diagnostic Circuit Diagram
Terminal & Connector Inspection
1.
Many malfunctions in the electrical system are caused by poor harness and terminals.
Faults can also be caused by interference from other electrical systems, and mechanical or chemical damage.
2.
Thoroughly check connectors for looseness, poor connection, bending, corrosion, contamination, deterioration, or damage.
3.
Has a problem been found?
▶ Repair as necessary and go to "Verification of vehicle Repair" procedure.
▶ Go to "Power circuit inspection" procedure.
■ Check Open in power circuit
1.
IG "OFF".
2.
Disconnect Injection Pump(Fuel Quantity Adjust Resistor) connector.
3.
IG "ON"
4.
Measure voltage between power terminal of the Fuel Quantity Adjust Resistor harness connector and chassis ground.
Specification : 4.5 ~ 5.0 [V]
5.
Is the measured voltage within specification ?
▶ Go to "Ground Circuit Inspection" procedure.
▶ Go to "Check Short in ground circuit" procedure.
■ Check Short in ground circuit
1.
IG KEY "OFF".
2.
Disconnect Injection Pump(Fuel Quantity Adjust Resistor) connector and ECM connector.
3.
Measure the resistance between power input terminal of of Fuel Quantity Adjust Resistor harness connector and chassis ground.
Specification : ∞
4.
Is the measured resistance within specification ?
▶ Go to "Check Short in battery circuit" procedure.
▶ Repair Short to ground in power circuit and then, go to "Verification of Vehicle Repair" procedure.
■ Check Short in battery circuit
1.
IG KEY "OFF".
2.
3.
IG KEY "ON".
4.
Specification : 0.0V~0.1V
5.
▶ Repair Open in power circuit and then, go to "Verification of Vehicle Repair" procedure.
▶ Repair Short to battery in power circuit and then, go to "Verification of Vehicle Repair" procedure.
Ground circuit inspection
■ Check Open in ground circuit
1.
IG KEY "OFF".
2.
3.
Measure the resistance between ground terminal of Fuel Quantity Adjust Resistor harness connector and ECM harness connector.
Specification : Below Approx 1Ω
4.
▶ Go to "Component inspection" procedure.
▶ Repair Open in ground circuit and then, go to "Verification of Vehicle Repair" procedure.
Component Inspection
■ Check Fuel Quantity Adjust Resistor component resistance
1.
IG KEY "OFF".
2.
3.
Measure the resistance between power terminal and ground terminal of Fuel Quantity Adjust Resistor (component side).
Specification :
Adjust
№3 0.43 №8 2 №13 15
№4 0.62 №9 2.7
№5 0.82 №10 3.9
4.
▶ Substitute with a known - good ECM and check for proper operation.
If the problem is corrected, replace ECM and go to "Verification of Vehicle Repair" procedure.
▶ Substitute with a known-good Injection Pump(Fuel Quantity Adjust Resistor) and check for proper operation.
If the problem is corrected, replace Injection Pump(Fuel Quantity Adjust Resistor) and then go to "Verification of Vehicle Repair" procedure.
After a repair, it is essential to verify that the fault has been corrected.
1.
After connecting Scantool select "DIAGNOSTIC TROUBLE CODES(DTCs)" mode.
2.
Clear recorded DTC using Scantool.
3.
Drive the vehicle within DTC "Enable conditions" in "General information".
4.
After selecting "DIAGNOSTIC TROUBLE CODES(DTCs)" mode and check if DTC is recorded again.
5.
Are any DTCs recorded ?
▶ Go to the DTC guide of recorded NO. in Scantool.
▶ System operates within specification.
em bói có thể xe cụ bị hỏng bơm cao áp hoặc trong tháo lắp cụ chưa súc sạch hệ thống làm mát khí tu bô ,cụ kiểm tra súc rửa lại ống xả xem còn nhiều dầu đọng trước đây không nhé .Kèm theo cụ kiểm tra thêm có thể thiếu mát dẫn về hộp .Em đoán được có thế thôi cụ à có gì các cụ chém tiếm nhé.
